Hot Bodies Cyclone >
Hot Bodies Cyclone
Hot Bodies Cyclone
Old 03-22-2010, 02:22 AM
  #18811
Korey Harbke's Avatar
Trader Rating: 13 (100%+)
Originally Posted by cosmo1974
Hi Korey,
(1) The topic about "cooking" the tires came up at the weekend practice day.
I realised I did not fully understand the logic behind this.
If the shocks are laid way down:
-- The wheel rate is reduced ("softer"), but on the other hand,
-- The shock is not working as much
(2) So, why does laying the shocks down (a lot) reduce tire heating (at a TITC like track) ??
Thanks in advance
Generally the tire is loaded and unloaded really fast and aggressively with stood up shocks. Shocks that are more laid down make the the car transfer weight slower side to side. So it helps not load the tire so abruptly. Thats how I feel it keeps tire temperatures a little cooler... to a point. You still need to make sure the car isn't sliding around. I feel shock oil has a greater effect on tire temperature. If you are overheating your tires, thicker oil helps a lot.
-Korey
Korey Harbke is offline
Old 03-22-2010, 02:24 AM
  #18812
Originally Posted by RLMW VQ
korey how is the exotek chassis?
what are the differences between the stock tc chassis and exotek?
Its really good. It's helped my car out a lot in lower traction conditions, and makes the car very easy to drive. Felt like it had more grip overall, most likely due to the added flex. Plus balancing out the chassis is super easy.
-Korey
Old 03-22-2010, 03:18 AM
  #18813
cosmo1974's Avatar
-Korey
I will be able to pass this info onto others as well.
cosmo1974 is offline
Old 03-22-2010, 06:16 AM
  #18814
Trader Rating: 18 (100%+)
HI,
I raced yesterday with my Cyclone on indoor carpet with a 17.5 Novak motor/GTB ESC. I was able to complete a qualif of 8 minutes normally but I found the motor was a little hot. First time racing 8 minutes so I thought it should be okay for the main and I could check the gearing later. But in the main (still 8 minutes) I was able to only race for 5 minutes before the motor got cut off by ESC because it was wayyy too hot.
I'm running the following gearing and would like suggestion for next race.
Spur = 100 64P
Pinion = 50 64P
Pulley = 18T
FDR = 4.33
Tire = Sorex 28
Thanks,
thejo3 is offline
Old 03-22-2010, 04:26 PM
  #18815
cyclone x's Avatar
is it true there will be a new cyclone soon
cyclone x is offline
Old 03-22-2010, 04:47 PM
  #18816
callender89's Avatar
Trader Rating: 33 (100%+)
Just picked up a cyclone TC, new to this on road world. I was wondering what type of servo should i go with?
Thanks in advance
callender89 is offline
Old 03-22-2010, 05:03 PM
  #18817
RLMW VQ's Avatar
Trader Rating: 11 (100%+)
ko 2413ics servo is the best
and cyclone x yes there is a new car coming
RLMW VQ is offline
Old 03-22-2010, 06:53 PM
  #18818
cosmo1974's Avatar
Thanks in advance
I purchased one of the servos recommended to me on this forum.
Its the Futaba BLS 551, brushless, low profile.
Very nice
Old 03-22-2010, 07:47 PM
  #18819
jag88's Avatar
Very nice
+1
jag88 is offline
Old 03-22-2010, 07:50 PM
  #18820
kschu's Avatar
Trader Rating: 16 (100%+)
Very nice
try savox lpf...quite good...
kschu is offline
Old 03-22-2010, 10:08 PM
  #18821
Thanks guys! With this new chassis coming out, I hope they will still have plenty of spare parts for the tc!
Old 03-23-2010, 06:41 AM
  #18822
What would be a good spur and pinion for a moorespeed cyclone with a 7.5 turn brushless novak? My friend told me that the fdr is 7...
AVILLA is offline
Old 03-23-2010, 07:59 PM
  #18823
san.'s Avatar
Trader Rating: 61 (100%+)
Going to run my TC for the first time on asphalt. What are you guys/gals doing to prevent the chassis from getting destroyed with all the rubbing?
My base setup will be Hara's Reedy Race.
Thx.
san. is offline
Old 03-23-2010, 08:23 PM
  #18824
RLMW VQ's Avatar
i like the associated protector its alittle thick but i have never had anything penitrate it and hurt the chassis.
RLMW VQ is offline
Old 03-23-2010, 08:32 PM
  #18825
tha Beast's Avatar
Trader Rating: 100 (99%+)
yeah the associated is the best but if your running on asphalt getting scuffs and scratches on the chassis is probably gonna happen anyway
BTW guys im new to rctech and new to 1/10scale but i have been following this thread for a few weeks now. im not new to RC i have been running mini-z's for about 3 years(i have only been in RC for 3 years) ) im currently running a cyclone tc with a little bit of Hara's Reedy setup and some of my own. i have yet to try some of the setups posted here, i must say you guys really know your stuff. im sure ill be asking alot of questions soon anyway i just wanted to say hello
tha Beast is offline
