Hot Bodies Cyclone >
Hot Bodies Cyclone
Hot Bodies Cyclone
Old 05-08-2011, 07:33 PM
  #19561
k_bojar's Avatar
Trader Rating: 30 (100%+)
Originally Posted by dirt_oval
Is there anyway to use a TC5 Ball diff in the rear of the cyclone?
why would you need to do that??
if you did, you'd need:
correct belts - don't think the standard cyclone's will work
bearings
outdrives/cvd shafts (if the stock ones don't work)
k_bojar is offline
Old 05-08-2011, 07:50 PM
  #19562
Trader Rating: 42 (98%+)
Because I am needing one by this Friday, and can not find one on the web.. and my brother has an extra and I figured I would ask..
dirt_oval is offline
Old 05-08-2011, 09:03 PM
  #19563
ShaunMac's Avatar
Originally Posted by mtsb4
Anyone got some things to look at when trying to reduce understeer.
Running the same tires as others at the track, the rear seems stiffer than the front.
diff is slipping a little at the moment.
added a little more camber and that helped a little.
just looking for a few ideas
Tighten up your diff. It should be smooth and not slipping.
Post your setup if possible. It will help others help you out much better.
Asphalt? Carpet?
ShaunMac is offline
Old 05-09-2011, 06:48 AM
  #19564
So does anyone have a spare diff they could possibly sell me?
Old 05-09-2011, 12:24 PM
  #19565
Old 05-12-2011, 08:40 PM
  #19566
I got everything sorted out.. However, my car seems like it pushes a bit coming into the corner... Actually it pushes a lot, where as I kind of have to use the brakes to swing it around. What do I need to change to give me a more turn-in? rear droop? It was a previous asphalt car, so I am trying to make the switch to carpet with it!
Old 05-13-2011, 02:30 AM
  #19567
waggaclint's Avatar
Recently picked up a Cyclone TC roller and was wondering if someone could recommend a good servo to use..
Also im new to on-road so is there any tips etc i need to no about the cyclone tc..
Cheers Clint
waggaclint is offline
Old 05-13-2011, 09:34 AM
  #19568
Suspended
RaceAce701's Avatar
Trader Rating: 87 (99%+)
futaba 9951 works great and wont hang off the chassis
http://www3.towerhobbies.com/cgi-bin...&I=LXRWS8&P=ML
RaceAce701 is offline
Old 05-13-2011, 08:59 PM
  #19569
waggaclint's Avatar
Thanks i thought i might need a low profile one, Ive got a Hitec HS-5645MG spare but when mounted its very close to the belt..
I was looking at a Savox SC-1251MG..
Old 05-14-2011, 05:06 AM
  #19570
k_bojar's Avatar
the savox is also a good choice - the same size of the futaba, but 2/3 the price
I just replaced both of my 9551's with the savox servos
k_bojar is offline
Old 05-14-2011, 05:18 AM
  #19571
GasGod's Avatar
Anyone know if any other diffs fit the cyclone?kinda tire'd of tryin ta find HB parts.I hear the tc5 diffs fit--true? thanx in advance.
GasGod is offline
Old 05-14-2011, 10:26 AM
  #19572
the 1251s are great. I love low pros, Especially with my exotek chassis!
Old 05-15-2011, 05:29 AM
  #19573
Craig W's Avatar
Originally Posted by RC MARKET
My Cyclone TC Gear Diff
What gear diff is it please
Craig W is offline
Old 05-15-2011, 05:32 AM
  #19574
Craig W's Avatar
will top racing gear diff fit or a yok 1
Craig W is offline
Old 05-15-2011, 04:15 PM
  #19575
warnos's Avatar
Default Spec R
Hi mate just get a Spec R gear diff for the TCX.. have one in the rear of my Cyclone and its works fine.. use it with 2000 oil and its perfect.. just get some automotive silicone sealant to use with it to make sure it doesn't leak.. also u will need to use a couple of shims on the diff to make sure there is not too much movement..
Cheers
warnos is offline
