Hot Bodies Cyclone >
Hot Bodies Cyclone
Hot Bodies Cyclone
Old 04-25-2011, 07:36 AM
  #19546
Giorgio's Avatar
Originally Posted by Dog Bone
I'm looking for something other than another Exotek chassis guys, as I've already had two fail.
But thanks for suggesting Exotek
Which kind of issues have you had you Exotek chassis? Justo to know.... I don't have any original chassis as spare....
Giorgio is offline
Old 04-25-2011, 11:19 AM
  #19547
k_bojar's Avatar
Trader Rating: 30 (100%+)
not sure if anyone other then Exotek made one for the TC
k_bojar is offline
Old 05-03-2011, 07:29 AM
  #19548
nf_ekt's Avatar
Trader Rating: 115 (100%+)
Quick question- Is there any difference in the TC version chassis and the WCE chassis? I have the WCE and want to put a fresh chassis on it for carpet (current one is pretty beat). Thanks.
nf_ekt is offline
Old 05-03-2011, 08:46 AM
  #19549
Trader Rating: 19 (100%+)
I still have that NIP if you're interested.
Advil is offline
Old 05-03-2011, 10:02 AM
  #19550
nf_ekt's Avatar
Forgot about that. I may hit you up to grab that, just waiting on the carpet track to open locally (running some asphalt right now, but once I go carpet I'm staying that way)
nf_ekt is offline
Old 05-03-2011, 11:14 AM
  #19551
OVA
OVA's Avatar
Trader Rating: 86 (100%+)
what is the lenght of the Hot Bodes DCJ universal 44mm or 46mm ?
OVA is offline
Old 05-03-2011, 11:27 AM
  #19552
44mm
Advil is offline
Old 05-03-2011, 11:32 AM
  #19553
Anybody know where I can get a 2.5mm topdeck (UK preferably)?
markrobinson is offline
Old 05-05-2011, 03:39 AM
  #19554
I have been looking at set up sheets and when it points to what i think are the rear pivot blocks (F 1.5 R 1.5) is that two 1.5 deg blocks in the rear making 0 deg toe in?
mtsb4 is offline
Old 05-05-2011, 11:18 AM
  #19555
It's probably a reference to the spacers used under the toe blocks
JR007 is offline
Old 05-05-2011, 11:21 AM
  #19556
nf_ekt's Avatar
What brand / weight oil would any of you recommend for low-traction asphalt? and pistons?
nf_ekt is offline
Old 05-05-2011, 03:16 PM
  #19557
warnos's Avatar
3 hole pistons.. Muchmore oil... 450.. which is about 37.5 wt..
warnos is offline
Old 05-05-2011, 07:32 PM
  #19558
nf_ekt's Avatar
Thanks. What is your take on sway bars for this type of surface? I'm thinking I will take them off for now.
nf_ekt is offline
Old 05-06-2011, 01:18 AM
  #19559
Anyone got some things to look at when trying to reduce understeer.
Running the same tires as others at the track, the rear seems stiffer than the front.
diff is slipping a little at the moment.
added a little more camber and that helped a little.
just looking for a few ideas
mtsb4 is offline
Old 05-08-2011, 06:25 PM
  #19560
Trader Rating: 42 (98%+)
Is there anyway to use a TC5 Ball diff in the rear of the cyclone?
dirt_oval is offline
