Hot Bodies Cyclone >
Hot Bodies Cyclone
Hot Bodies Cyclone
Old 04-23-2008, 10:07 AM
  #12046
SammyZ's Avatar
Trader Rating: 138 (100%+)
Originally Posted by CRASH
I still have the "Original Black Cyclone" and it is till extremely competitive. I have been slowly but surely upgrading to all the newer parts. The "COOL BLUE"!
Does the new TC car revert back to the Version 2 drive shafts or does it still use the WCE CVDs?
Later,
yes they did revert on their updated car LOL
SammyZ is offline
Old 04-23-2008, 01:03 PM
  #12047
Hebiki's Avatar
Trader Rating: 26 (100%+)
can someone please post their complete asphalt/rubber tire set up for their cyclone? id like to compare it to some of the changes ive made to mine for this weekend's race. thanks!
Hebiki is offline
Old 04-23-2008, 01:06 PM
  #12048
Syber Serulean's Avatar
Trader Rating: 28 (100%+)
my setup works really well for me...
but i dont know it haha. I bought it and left it the way it was @_@
been meaning to put it on a setup station and write everything down...i should do that...
Syber Serulean is offline
Old 04-23-2008, 01:22 PM
  #12049
Super Moderator
charlie_b's Avatar
Originally Posted by STLNLST
Just because I'm bored.....LOL
Clint u should post that on CFX..btw..have u even been on there and registered?
Anyway, back to Cyclone talk.
charlie_b is offline
Old 04-23-2008, 01:43 PM
  #12050
I think the CVD pins (moore edition) are 1.5x11mm pins and the universal joint pins (hara edition) are 2x10mm pins.
bionictony is offline
Old 04-23-2008, 07:22 PM
  #12051
karlo511's Avatar
i've been running this set-up
http://www.petitrc.com/reglages/hotb...etup200712.pdf
but i made the following changes:
front block = F 1mm R 1.5mm
front droop = 6
front oil = 40wt
front spring = hpi white
rear droop = 6
rear ride height = 5.3
rear oil = 30wt
rear spring = hpi pink
tamiya red foam on top of bladders
front suspension arm spacer = F.5mm R 2mm
rear suspension arm spacer = F 2mm R .5mm
rear upright spacer = F 2.75mm R
other things to try:
1.2 mm front sway bar
reduce the rear toe-in block to 2.5
karlo511 is offline
Old 04-23-2008, 09:55 PM
  #12052
Karlo, the setup looks good.
are you racing this coming Saturday at BCR? since you didn't make the HB race #5 last weekend, you should make it this weekend!!
Hi-LowBlow is offline
Old 04-24-2008, 06:21 AM
  #12053
STLNLST's Avatar
Trader Rating: 32 (100%+)
I may have to go and check it out. I still never fully recovered from coming in 2nd to your Darth Maul (sp) paint job and the Norrca nats back in the day
STLNLST is offline
Old 04-24-2008, 06:28 AM
  #12054
HarshGuy's Avatar
Sounds almost as bad as not even placing at the paint job contest @ ROCKS
HarshGuy is offline
Old 04-24-2008, 06:33 AM
  #12055
STLNLST's Avatar
You had to bring that up again huh. That was crap losing to a two color rattle can paint job and another one that was all sticker's. That's why I will never enter that contest again. They play favorite's. I really like the rule that you had to paint the body yourself yet just about everyone there had their bodies painted by that one girl Oh well......I still have my 2nd place to Charlie B. trophy
STLNLST is offline
Old 04-24-2008, 02:35 PM
  #12056
Hebiki's Avatar
front droop = 6
front oil = 40wt
rear droop = 6
rear oil = 30wt
thanks dude. im going to print this out and look it over. ive seen your cars they're always very stable in low traction tracks like Corona and LM.
Hebiki is offline
Old 04-24-2008, 03:20 PM
  #12057
hey Chris where you gonna be pitting? Gonna wanna ask you how that setup works for you this weekend...
as long as i been doing onroad, im still nooby to setting up a car other than shock position, camber and toe-in (even then im still nooby), shock oil weight, and springs.
@_@
Old 04-24-2008, 03:52 PM
  #12058
karlo511's Avatar
steve weiss posted that set-up a couple years back and i always start with it and adjust from there.
karlo511 is offline
Old 04-24-2008, 04:06 PM
  #12059
whats the suggested rear plate thing for medium to low asphalt track conditions? Right now i have th aluminum rear plate like the WCE kit would include. Between the FRP plate, the carbon fiber plate, and a modded plastic cyclone S rear plate, whats the best to use in this scenario and what are the disadvantages if any?
Old 04-24-2008, 04:17 PM
  #12060
dstyles's Avatar
anything but the aluminum would benefit you. the plastic S deck with the webbing cut out or the FRP plate work would work well. it won't give you a drastic traction change, but it will allow the rear to flex a little more than the aluminum piece.
dstyles is offline
