Hot Bodies Cyclone >
Hot Bodies Cyclone
Hot Bodies Cyclone
Old 03-26-2010, 03:42 PM
  #18841
Trader Rating: 20 (100%+)
I am confused with the TC arm mounting positions. I want the rear to feel softer without moving the shock position on the tower. I now have it on the three position. Would moving it more inside make it softer or outward towards the tire?
goots is offline
Old 03-26-2010, 08:53 PM
  #18842
tha Beast's Avatar
Trader Rating: 100 (99%+)
try putting a thinner spacer(shim) under the camber link it worked for me
tha Beast is offline
Old 03-26-2010, 10:06 PM
  #18843
Well yes I know, but that does not answer my question. I want to know the affect of the the different arm positions on the TC
goots is offline
Old 03-26-2010, 10:46 PM
  #18844
EJ20's Avatar
I would try hole#2 on the TC arms (rear), it feels softer and rotates better especially when on power.
EJ20 is offline
Old 03-27-2010, 02:21 AM
  #18845
Im looking for the theory behind the mounting positions. So 1 being the softest 5 being the hardest? or is it reverse? hmmm maybe im asking the wrong question....
goots is offline
Old 03-27-2010, 04:04 PM
  #18846
mac853's Avatar
Questions??
Could somebody confirm for me if this part is for direct drive?
Best regards
mac853 is offline
Old 03-27-2010, 05:04 PM
  #18847
jonny123's Avatar
Best regards
Yes, as it has the flat spots on both sides of
the layshaft so is for direct drive :-)
Jonny
jonny123 is offline
Old 03-27-2010, 11:28 PM
  #18848
Originally Posted by madwestmo
I dont know if anyone has mentioned it but the only thing that i dislike about my cyclone TC is not been able to change the pinion without removing my battery , any solution ? apart from trimming bit off motor shaft
anyone ?
madwestmo is offline
Old 03-28-2010, 02:11 AM
  #18849
mac853's Avatar
Jonny
OK, thanks!
mac853 is offline
Old 03-28-2010, 02:42 AM
  #18850
Korey Harbke's Avatar
Figured I'd give you guys a shot at this... Although Charlie might come by and smack me on the head
http://www.rctech.net/forum/r-c-item...assis-kit.html
-Korey
Korey Harbke is offline
Old 03-28-2010, 02:54 AM
  #18851
Airwave's Avatar
Best regards
I bought two of them, use the first one... At the end of the first pack it was totally twisted and unusable...
I sell directly the second...
Now I use the original axle with the Square option :
view here
Airwave is offline
Old 03-28-2010, 02:58 AM
  #18852
tha Beast's Avatar
view here
i use both stcok parts and ive never had a problem and im running a 5.5turn
but ive never been a fan of 3racing
Old 03-28-2010, 11:33 AM
  #18853
Phil C's Avatar
1 is the stiffest setting, 5 is the softest...
Moving the lower shock position further outboard (towards the wheel) gives the wishbone less leverage on the shock which makes the suspension stiffer.
Moving the lower shock position further inboard (away from the wheel) gives the wishbone more leverage on the shock, which makes the suspension softer.
Obviously unless you move the upper shock position so that the angle of the shock stays the same you will also feel the effect this has....
More angle on the shock makes the suspension 'regressive', meaning it gets softer the further it travels
Less angle on the shock makes it more linear, so compared to a more angled shock, it will feel stiffer as the car rolls.
Hope this helps.
Phil C is offline
Old 03-28-2010, 12:00 PM
  #18854
k_bojar's Avatar
Trader Rating: 30 (100%+)
view here
do you have the part number(s) for the Square parts?
k_bojar is offline
Old 03-28-2010, 07:35 PM
  #18855
Default New TC
Hi.
I just finished putting together my new Cyclone TC (just the electronics missing) and noticed a potential problem. The steering turnbuckles touch the front arm mounts when near full lock. Is this normal with this car ?
Storm_PT is offline
