HPI Vorza Flux 1/8 E-Buggy Thread
#751
![Default](https://www.rctech.net/forum/images/icons/icon1.gif)
how about this servo http://www3.towerhobbies.com/cgi-bin...&I=LXNRN6&P=SM
I have no experience with Hobbico stuff but I hear this is the same as the Hitec 7955 with a different label.
I use the 7985 in my Ve8 and I like it alot and I got mine for like $75 just look aroung I think Stormerhobbies.com.
#752
![](http://img522.imageshack.us/img522/2548/vorzaservocomparison.jpg)
#753
Hey
I just got a new Turnigy 6S 5000mah 30C battery pack from HK. This thing is HUUUGE!!! So I put it in the car and noticed that the body is touching the battery... Even getting pushed up a few millimeters. That beeing placed with the wires on the side.
Im worried that as soon as the car rolls and hits a small bump or something, the battery is going to take the hit and burst into flames... = bye bye 600 $ car + 100$ receiver.
What to do?
What to do?
![Confused](https://www.rctech.net/forum/classic_images/smilies/confused.gif)
#755
Lol, just paid 90 bucks for a battery and now it doesnt fit ![Mad](https://www.rctech.net/forum/classic_images/smilies/mad.gif)
Are no one else using Turnigys or Zippys 6s?
#756
Just trying to think of things you can do.
#757
So the problem here is that the battery is too tall and is pushing the body up?
Can you fit the battery in on its side?
Did you remove the two padded tabs at the bottom of the battery tray? That should give more clearance.
#758
Is the battery a hard or soft case? Can you put few washers under the body to raise it. What about the body mounts can they be moved? If you can get the body a little higher you can alway put a thin piece rubber foam or something on top of the battery.
I also thought of removing the padded tabs, but i'm worried that when the chassi hits the ground the force will be too much for the lipo to handle. The pads are there for protection and not just "spacers", right?
#759
You can always ebay the battery and buy the 4s 14.8.That is one of the things I noticed from pics is the battery is very high .I didnt even think of it hitting the body I just figured ballance was the worst issue.
#760
Anyone know if these would be the right ones.I have been a fan of outerwears since my baja and I would like to get these for the Vorza
http://www.outerwearsracing.com/prod...prod=44%2D2438
#761
What happened was is you went to high in mah. If you didnt solder it send it back for a 3600 or something. You get more runtime out of hgher cell counts but you have to get the appropriate KV motor for this. But 6s will still give you a tad more runtime than 4s packs with the same mah eve with the ame motor as long as you gear it properly. With the CC/2200 really with the fact that you can gear it to the moon on 4s without it getting too hot there really is no need for more than 5S usage. If you use the speed-gearing chart with 4s 5s and 6s and go a few teeth smaller each cell you go up you will see the top speed will stay the same. I hope that made sense and sorry if not.
#762
Assuming I use the same spur gear with a 4s 14.8volt 5000mah battery What could be my best pinion size or should I just keep it stock?I would experiment but at 15 dollars a pinion I dont want to waste my money.thanks
Btw still need answers on the shock covers from earlier.Thanks again.
#764
Hey
What to do?![Confused](https://www.rctech.net/forum/classic_images/smilies/confused.gif)
What to do?
![](http://www.strikingvisions.com/vorza8.jpg)
