Capricorn LAB-C01 >
Capricorn LAB-C01
Capricorn LAB-C01
Old 07-12-2013 | 01:22 AM
  #2056
Originally Posted by DS Motorsport
If you want to make it a bit smoother just turn back the preload a bit. I always adjust the clutch preload when traction is low.
Or change the throttle response artificially by putting a curve on your throttle channel in your transmitter.
Or just pull the throttle a bit more gently.
With best overall I mean it's the best performing set, clutch hits hard and the engine spools up quickly.
Hardcoated bell: http://www.capricornrc.nl/Webwinkel-...B-C01-C02.html
Yellow shoe: http://www.capricornrc.nl/Webwinkel-...utch-shoe.html
Spring tension is almost on the loosest part and tried every type of electronic help. Clutch is to good for our track to snappy. in need of a bit more slip.
So basically the yellow pad will just make it worse as it seems that the punch will be greater?
I will also try a softer spring to try and solve the issue, I also believe that the engine bottom end is quite powerful so it could be the cause of the issue.
I am running a .30 gap to try stall a bit the engine and still rips.
Engine is a Keep On with Capricorn Exhaust
speed6 is offline
Old 07-12-2013 | 05:28 AM
  #2057
British Menace's Avatar
You need to find a softer spring so the clutch engages earlier
Try some of the old TM clutch springs .....
BM
British Menace is offline
Old 07-12-2013 | 01:22 PM
  #2058
djiewie's Avatar
Try to find it in the setup. Put some more front drive in it.
More slack in the rear belt and put the front belts tighter without slack.
Remove the play in the front spurs.
Try the steel bell with the yellow shoe,
try the 19 tooth spur in stead of the 18tooth on the tranny axle. But it will wear the spurs faster, use harder front tires with this
with a 4mm split.
put more droop in the front from 1 to 0.
Hope you tell us what you tried and if you were helped. Have fun
djiewie is offline
Old 07-15-2013 | 07:56 AM
  #2059
blackyblackman's Avatar
NEW Capricorn LAB C01 Kit for sale!!!
For sale/trade forum: http://www.rctech.net/forum/r-c-item...n-lab-c01.html
blackyblackman is offline
Old 07-16-2013 | 09:12 AM
  #2060
with a 4mm split.
Remove play in the front spurs? can you explain better plz
never thought you could use the belt tension for handling purposes very interesting.
19tooth instead of 18tooth the Kevlar one opposite the 1st and 2nd?
speed6 is offline
