Old 04-16-2013, 02:05 AM   #2026
Originally Posted by 1evo RRR Driver View Post
Should be VZW215-15 But keep in mind that 15t is steel! Going to last forever, but I'm sure it will affect spool up and acceleration! I have one but I haven't used it yet, it's like 5xs heavier than the aluminum cap pinion!!
Is the VZW066-20 a good fit for the second gear?
I know its a lot heavier and I will loose acceleration, but for practice or club level racing I think it might be enough.
ma_RC_el is offline   Reply With Quote
Old 04-16-2013, 02:14 AM   #2027
1evo RRR Driver's Avatar
Send a message via AIM to 1evo RRR Driver
I haven't personally tried the kyosho pinions yet, but they'll thread right on a cap bell no problem!!
"He's CHEATIN! cause Im CHEATIN! and He beat ME!" :) "TKI4 PILOT" /XRAY NT1 16' /FUSION X3LCFM / M2c / PROTEK / FUTABA 4PX / SAMURAI
1evo RRR Driver is offline   Reply With Quote
Old 04-16-2013, 11:40 AM   #2028
gsxr0311's Avatar
Trader Rating: 19 (100%+)
hay ds motorsports, any eta on the receiver boxes? thanks
Special Thanks to: RC Target, Ko Propo USA, A Main Hobbies-SWORKz USA, R1 Wurks, and Absolute Hobbies.
Capricorn: LAB-C802, LAB E801, LAB-C03, TE03, and P01 235mm. IGT8. SWORKz: S350BK1 EVO II, S104EVO, S12-1M. Top Rebel 12.
gsxr0311 is offline   Reply With Quote
Old 04-16-2013, 03:53 PM   #2029
gsxr0311's Avatar
Old 04-16-2013, 11:56 PM   #2030
MrHistory's Avatar
Originally Posted by DS Motorsport View Post
Finished my custom receiver box:
Need to make some small changes to the design (too thin in some spots) but the overall fit and finish is very nice. The 471 receiver from Sanwa fits perfectly.
Now that I know the minium wall thickness and design features of the material I will start with the design of the universal receiver box for the standard Capricorn cars.
The receiver box looks very nice. It's always great to see you are making your own designs. What is the white radio tray in that photo, the close up is hard to make out?
My first thought is that that the box should float and not touch the bottom chassis plate as this will cause tweak and binding, not allowing the car to flex evenly. Also, aren't prototyping plastics very brittle?
I would love to have a nice receiver box for the KO 409/411. I tried the mtx box and Pietch seems to have designed it to fit perfectly around his Sanwa. The KO does fit with the larger cover piece but its about the size of the fuel tank
Irwin RC 1/8th Pan Car Specialists - www.irwinrc.com
SPM Competition, WRC Racing, MIP, Novarossi
MrHistory is offline   Reply With Quote
Old 05-09-2013, 11:29 AM   #2031
gsxr0311's Avatar
Anybody going to try those big bore shocks?
Old 05-09-2013, 11:33 AM   #2032
YBSLOW's Avatar
Yes
I think they will be good on high bite smooth track due to the lower cg.
YBSLOW Racing
RC Target - Capricorn
HOTRACE Tyres, Tru Source, Fantom
POWER MASTER Fuel, 2mm Designs
Protoform Bodies, Avid Bearings, AMR Engines
YBSLOW is offline   Reply With Quote
Old 05-09-2013, 11:34 AM   #2033
dj apolaro's Avatar
I should be testing them at the KO race next weekend. This weekend I will be building them.
DJ
Capricorn RC, Capricorn Tires, Novarossi World, Spektrum, Horizon Hobby, PROTOform, RCTarget, IGT8.
dj apolaro is offline   Reply With Quote
Old 05-09-2013, 01:02 PM   #2034
British Menace's Avatar
Just waiting for them to come ...... going to fit and test straight after. I just learnt they come with 6 hole pistons. So some testing to see what oils to use. I'm thinking we'll have to go thicker by 100cst. We'll see.
BM
So enjoying building cars I sometimes forget to save some "man-time" to race them!?
British Menace is offline   Reply With Quote
Old 05-09-2013, 01:10 PM   #2035
dj apolaro's Avatar
they come with 6 hole piston, however you can order other ones. I am building mine with one hole in the front and 2 hole iin the rear like I always do.
DJ Apolaro
Old 05-12-2013, 08:49 PM   #2036
gsxr0311's Avatar
ok. nice, cant wait to hear the results. this should be good dj because since the ko layout is the same you can see if they are faster than the originals.
Old 06-02-2013, 05:12 PM   #2037
gsxr0311's Avatar
has anybody tried the new shocks, if so how were they? thanks.
Old 07-01-2013, 01:35 PM   #2038
DS Motorsport's Avatar
Default LP Big bore shocks
Last sunday I finally had the time to test the new big bore shocks.
Design and quality is really good, as usual. I did had one piston which was slightly scraping the shock housing so I placed it in the dremel and sanded it a bit with 1000 grit sanding paper.
The fit of the pistons in the shock housing is very close, almost no play in the shockshaft.
The shocks come with 6 hole pistons with 1.2mm holes and 3.4kg 5.5 winding springs.
I also received the new springs and some different pistons.
I build the shocks with the 6 hole pistons and tried different oils to get a similar feel to my normal shocks ([email protected]). I ended up with 1000cst oil.
For the springs I started with the 4.1kg in the front and 3.9 in the rear. This are in between of the red and black full length springs in term of stiffness.
The car felt good with these settings, but was a bit too easy to drive. Suffered from initial and mid corner understeer. So also fitted the 3.9 springs in the front and this worked really well.
I didn't had time to try the standard springs, I think they are too soft but maybe they will work because of the car will roll a bit less.
I will need to do more testing with oils and pistons but I think my settings are a really good starting set.
So standard 6 hole pistons with 1000cst and 3.9kg springs all around.
P1-RC.com
DS Motorsport is offline   Reply With Quote
Old 07-01-2013, 04:40 PM   #2039
el salvador's Avatar
Thumbs up Big Bore Shocks
Interesting what Daan and DJ have offered so far about these parts.
With both a C01 and C02 thread to keep track of, it's a little confusing to make sense of, however:
I believe on the C02 thread DJ mentioned he had to make to fit rear/lower ball cups in order to get the right amount of down travel (ie, the piston sitting in the desireable location in the shock body @ static ride height), and that is also what I found as well. Since I have lots of Kyosho RRR parts to modify, thats what I've done. Using the middle of the 3 sizes of ball cups, I shortened these .7 mm, together with the 4.8 mm ball studs and the "Flat/Older Generation" spring seats and Gold (stiffest front) springs now has the Rear suspension to my liking. I also discovered that the early RRR front springs work very well in both front and rear locations.
The front end used all the parts as supplied and 80 wt Associated Oil in all 4 dampers.
Ran the Car Saturday at Timezome and by the 3rd qual it was very good.
Hey Trevor, you gonna make it to the TZGP ?
ARC R8 X2/ Max RP9 or O.S. R2101 ,Capricorn LAB C02-TOP Elite R, ARC R11....
"Every Cemetery in Chicago Votes Democrat!"
el salvador is offline   Reply With Quote
Old 07-04-2013, 07:42 AM   #2040
Default Clutch Pad that slips more
Hey all, is their a Clutch pad that slips a bit more than the RED compound
speed6 is offline   Reply With Quote
All my reviews. romuald31 Onroad Nitro Engine Zone 35 12-02-2013 08:01 AM
New Capricorn Touring Car romuald31 Nitro On-Road 90 01-25-2010 12:58 AM
V-ONE RRR WC vs. MTX-4 rmdhawaii Nitro On-Road 39 01-17-2010 01:25 PM
Tags
corn
