Old 01-16-2012, 01:46 PM   #1306
DS Motorsport's Avatar
Originally Posted by Chickentrader View Post
The CO1 magnesium bulkheads use 10 x 6 x 3 bearings for the layshaft; but the red CO2 bulkheads use 12 x 6 x 4 bearings, and no plastic inserts. It is possible that the plastic inserts will fit the red bulkheads however, and maybe the 12 x 6 x 4 bearings will fit the magnesium bulkheads if you don't use the inserts. Perhaps Patrizio will offer magnesium bulkheads for the CO2 with the plastic inserts sometimes in the future; we used the magnesium bulkheads in our CO1, and we never experienced any cracks in them.
The CO2 use plastic eccentrics for the rear diff though, and they are meant to dampen vibrations.
Kindest regards,
Lars.
The magnesium bulkheads fit the C02, this part hasn't changed.
With the Magnesium bulkheads I would advice to check the bearings very regularly since they are very small for the amount of loads they have to take.
The standard bearings also fit the magnesium bulkheads but this is not advisable as the bearings will eat away the magnesium very quickly.
In generally I would advice to check the two speed axle bearings regularly, especially the one on the gearbox side, together with the clutch bearings these are the most stressed bearings on the car.
I actually prefer ceramic bearings for the two speed axle and clutch, these are a lot more durable.
Regarding the two speed screws coming loose, make sure you don't over tighten them. There is very little material left for holding down the screws so they strip quite easily. Once you have overtightened them your spur will wobble or the screws come undone. To be sure you can also add a drop of ca glue in the spur gear before tightening the screws.
P1-RC.com
DS Motorsport is offline   Reply With Quote
Old 01-16-2012, 01:57 PM   #1307
NikoRacing's Avatar
for DS..
I read you use ceramic bearings... from which brand?
I'm thinking to get a set of them but I don't know what to choose..there are many and I don't want to throw away money to buy a set that run worst than a steel set.
Do anyone has feedback on the ABEC35 ones?
Thank you
NICOLA PEZZOTTI - italian F1 cat. driver - Serpent 747 - HIPEX exhaust system - HOTRACE tyres - SANWA M11X
NikoRacing is offline   Reply With Quote
Old 01-16-2012, 02:07 PM   #1308
Default Lab C02
Does the lab c02 come with the lighter 2 Speed Light Middle Shaft??
jorge858 is offline   Reply With Quote
Old 01-16-2012, 02:07 PM   #1309
Originally Posted by NikoRacing View Post
for DS..
Thank you
Last year I bought a set of Abec35 bearings but after one day of practice most of them were ruined. They felt very free when I build the car and I had everything shimmed out nicely. It might have been a bad batch or something but they were done within one day and never got a replacement set so I'm pretty much done with the abec35 bearings.
I've heard from others they were very pleased with them though.
After the abec's I got a set of Capricorn ceramic bearings which lasted the rest of the season but didn't feel as smooth as the abec ones. But they lasted without any maintenance so I think they are good.
For this year I'm getting a set of Acer racing bearings, I've heard nothing but good things about those so I thought it was interesting to give them a try.
Plus they give a full kit of bearings, not just the drivetrain bearings.
http://www.acerracing.com/ball_beari...-1421-135.html
P1-RC.com
Old 01-16-2012, 02:17 PM   #1310
No, it comes with the standard "full" two speed shaft. I also believe the lightweight two speed shaft isn't available anymore.
If you want to save even more driveline weight I can recommend the aluminum clutch bell set. It will increase the acceleration quite a bit.
P1-RC.com
Old 01-16-2012, 02:20 PM   #1311
for DS..
Thank you
BOCA BEARINGS yellow seal are maintance free and you can forget about them. Very good and very durable. All my engines and cars run their ceramics.
speed6 is offline   Reply With Quote
Old 01-16-2012, 02:25 PM   #1312
Chickentrader's Avatar
Originally Posted by nikoskar View Post
Nice photo.
You have P.M. regarding setup book downloads. Please let me know if the links don't work.
http://www.mediafire.com/?8csbtoqgawhuc6y
http://www.mediafire.com/?ha7re4w3r4hzboq
Kindest regards,
Lars.
Support your local RC stores - they support our sport!
Social media The empowerment of the small individual to enforce democratic process at the expense of dishonesty.
Chickentrader is offline   Reply With Quote
Old 01-16-2012, 03:13 PM   #1313
what the different in weight on the BELL CLUTCH 1/10 ERGAL - NEW from stock??
can can you use the BELL CLUTCH 1/10 ERGAL with the stock CLUTCH or you need anything else??
Old 01-16-2012, 03:19 PM   #1314
The stock bell weighs 7,1 grams and the aluminum bell weighs 3,0 grams.
You only need the black clutch shoe with aluminum bell (available as a set) to ensure best performance and best lifespan of both parts.
For the 1/8 aluminum bell you will also need the V2 pinions.
P1-RC.com
Old 01-16-2012, 03:55 PM   #1315
blis's Avatar
The insets are eccentric in our car; there is a the notch on flange that indicate the basic position, and belt tension is adjusted with by turning them either way.
We've also had a couple of issues the same loose screws; not enough to cause a problem in a race though, it just showed up during inspections. The problem was caused by us, by not making sure that the spurs were 100% tight against the other surface. We now put the 2 speed housing against something flat and tap the spur down on it to make it tight. More often than not we find that the screws need to be tighten up a bit more after tapping them down. But we also keep an eye on the screws, and inspect it every time that we take the spurs off the car.
Kindest regards,
Lars.
Now I'm worried.. LOL
Sorry Lars, you are correct, I was looking at the front's... Luke's has dad covered
RC Cars: E4/G4/TCX/LAB-C02/T4'15/MM Engines
WEB: Beachmums Racing - MYRCM Race Registration
Media: Amain - RCRacingTV - RedRC - LiveRC - blisx264
blis is offline   Reply With Quote
Old 01-16-2012, 08:51 PM   #1316
does the lab c02 come with BELL CLUTCH 1/10 ERGAL??
jjrctech is offline   Reply With Quote
Old 01-16-2012, 10:01 PM   #1317
The LAB C02 comes with the same clutch as on the CO1 which is metal bell and red shoe, the new swaybar is also an optional not included in the kit,it comes with the regular blade swaybar.
Rino Lino
___________________
www.RCtarget.com / SWEEP TIRES / IGT8 / TESLA ENGINES / KOSMIC FUEL / CAPRICORN /
Bodies by: www.era1FXcustoms.com
rinolino is offline   Reply With Quote
Old 01-17-2012, 12:49 AM   #1318
congrats to Rino Lino for the race of last WE
CapricornRC is offline   Reply With Quote
Old 01-17-2012, 07:03 AM   #1319
blis's Avatar
Default Home track - Capricorn RC Australia
So for those in the northern hemisphere dealing with the cold, something to tease you into visiting the home of motorsport in Australia.
http://www.beachmumsracing.org.au/Vic_2012_Teaser.mp4
Old 01-17-2012, 10:00 AM   #1320
nice vid!
SERPENT AMERICA / Desoto Racing / kosmic fuel
michael 1 is offline   Reply With Quote
All my reviews. romuald31 Onroad Nitro Engine Zone 35 12-02-2013 08:01 AM
New Capricorn Touring Car romuald31 Nitro On-Road 90 01-25-2010 12:58 AM
V-ONE RRR WC vs. MTX-4 rmdhawaii Nitro On-Road 39 01-17-2010 01:25 PM
Tags
corn
