Mamba Max Pro
#422
is cdog said you cant unsolder the wires. what I did was cut the wires off at the board. then drilled them out. and re installed TQ Racing wire. be careful that you use the right size drill bit and be sure to clean up you mess. because last thing you want is a little piece of solder or wire left over on the board and short something out.
I understand why they included the shorter wires with bullet connectors so it would be plug and play with their motors but they should of realized that a great number of the ESC's would end up powering ROAR legal spec motors which are normally hardwired to the ESC. Maybe a better option would of been to outfit the ESC with longer wires and include the connects loose. Alot easier to solder connectors to wire than to mess with replacing wire to the board.
#427
I like what the speedo has to offer, and the price. But the lack of solder tabs on a “pro” speedo is a cheesy. But for the price I can make do.
#428
I actually wouldn't mind some sort of a plug setup like on the Mamba Monster ESC, or, like how the Speed Passion V3 motors are coming now. I could then just make the wires the length I want, and then plug them into the ESC.
The plugs though would need to be top grade stuff, but I am sure castle could figure out something that would work excellent.
#429
hi guys, looking for a spec motor to power my slash but dunno which one i should get. Ill be running it with an MMP. IMO 10.5 on 2s for race track & 13.5 on 3s for general use, but i can only buy the one motor!
I suppose the 13.5 on 2s i could bump up the timing a little bit to get a few extra rpm, but also change a few settings on the MMP. The 10.5 on 3s however i may need to bump the timing right down & all the settings to low. Dont want to overheat, & i dont really want to have to make a dramatic change in gearing going from 3s to 2s....
#432
Track wont let us run anything umder 10.5. They want to keep the SCT class to spec so it can attract more people since its pretty cheap. My mate just had his slash around with an LRP 13.5, & that thing flew, i was very surprised. He is borrowing it from owner of LHS cause my mates BL system didnt come in. But my mate said the owner told him its a 13.5, but that thing had some get go, torquey little bastard, its made my choice alot easier now....
#433
1 cell Mod how to.......
here ya go........... the chip is clipped/glued into a holder, you have to bend the clip and remove the chip, i removed the clip as well so it didnt break loose and float around inside. Once you do this, the on/off switch no longer works and it will require a receiver pack to operate with 1 cell.
You HAVE to use the 1cellBeta software or it will not work
Here is where you can download the proper software, http://rcsoftware.web.officelive.com...3_MMP1Cell.zip
Double click this link. it is the unzipped file. it will take a little longer to download, (if it looks greyed out in your outlook or windows mail goto TOOLS>OPTIONS>SECURITY>uncheck do not allow attachments.)
http://ksgmotorsports.com/Castle/Cas..._MMP1Cell..exe
YOU CANNOT USE THE SOFTWARE DOWNLOADED FROM THE CASTLE CREATIONS SITE, 1 CELL SOFTWARE IS NOT AVAILABLE THERE, because its beta, I would expect a "production" version to be available after the 1 st run of factory 1 cell speedos.
The current 1 cell software (beta) has some prorgramming deleted to allow it to work with the modded 1 cell speedos.
DO NOT UPDATE THE SOFTWARE on your computer when it asks you too after you install it, it will update to NON 1 cell software. You must upload the 1 cell software/firmware to the speedo from your computer, BEFORE trying to use it.
hope this helps.
hope this helps.
#434
Has anyone had trouble using the mmp with novak sensored motors. My mmp startes erradically and cuts out with the two different Novak motors I've hooked to it. Both motors work fine with a losi esc. I've tried smart sence and sensored both react the same. Any help with this would be appreciated.
#435
