Mamba Max Pro
#451
I like the idea of solder posts, he only things I like about the RX8 is the solder posts and its semsored. I still wouldnt buy 1 though, which is why I am going to get this esc as soon as I get a motor for it. I am going to pair this with a V2 Speed Passion 9.5 2160kv 8th scale sensored motor on 4S. When they hit the US.
Does anyon have the MMM and MMP and could take a pic from above them? I am trying to get an idea on how much smaller the pro is.
#452
Sorry but this was a regular MMP and not the 1S version although I got to touch one of those 1C MMP as well. Intersting that both version I seen last night only had solder posts for the motor wires and not the battery wires. The posts are pretty tall, I would say about level with the heat sink. I was racing at the local indoor carpet/offroad track in Blue Springs, MO which happens to be the closest track to Castle Creations. Their shop is like 35 minutes from my house. The pro I refer to is Taylor James...you might of heard of him
#454
#456
I am running or trying to run a Ballistic 17.5 with mine and i cannot get the speed control to set up correctly. It recognizes full throttle but will not recognize full break and nuetral settings. The radio and RX are the ones that come thith the strike RTR I bought it so my daughter could run a brushless 17.5 system and everybody said the mamba pro was smooth but nobody around me can get it to work correctly.
#457
Anybody running the MM Pro in off-road?
Looking for a starting ESC setup for:
10th 2WD Stadium Truck 13.5 Novak Ballistic
AND
10th 2WD Buggy 10.5 Novak Ballistic
Just looking for any tips on what settings in particular I should pay attention to.
Thanks.
AND
Thanks.
#461
My ve8 ran a 15 minute main yesterday (almost 15... dumped right before it was over) with a 6s 2600/1400 t8 with the MMPro and it worked just fine. I believe it came off the track at 120 degrees although the ambient temps on the track were probably 35 degrees.
It seems to work fine, but until we get to run it outside in 90 degree heat with a broken fan, it is too early to say if it is suitable for 1/8 scale.
We used run with the regular MM with no problems, so I think the MM Pro will take it under most circumstances.
One did die at the track though... 4s/1900 but I think it may have been something else.
