SERPENT 120
Old 10-19-2009 | 03:14 PM
  #841
Originally Posted by gearhead_22
I am about get one. got my fingers crossed
The S120 is one of the nicest 1/12th cars I have ever run as long as you are running sub C nimh batteries. Serpent will be releasing a link version of the S120 soon. If you are planning on using single cell lipo batteries, you may want to wait until they release thier new link car. You can make a single cell lipo fit in the current S120 but does require that you place the battery on one side of the T bar and all of the electronics on the other side of the T bar opposite of the battery. You will have to add additional weight to the electronics side of the car to get it balanced and that will then put you over the 730 gm. minimum weight.
Other than that, it's an awesome car and I am sure the link version will be as well.
Crashby is offline
Old 10-19-2009 | 04:47 PM
  #842
gearhead_22's Avatar
thanks crashby, I do plan on using the sub c batteries.
gearhead_22 is offline
Old 10-23-2009 | 05:36 PM
  #843
KostaG's Avatar
Bump!
KostaG is offline
Old 10-23-2009 | 10:56 PM
  #844
mild seven's Avatar
I had my first run run with the S120 today and have to say i was pretty impressed. still needs some fine tuning but kit setup working pretty good so far.
mild seven is offline
Old 10-24-2009 | 08:44 AM
  #845
putting my s120 together this week, things not going to good. one of my slider blades broke and when I was snaping the e-clip on to the mono shock shaft, the shaft snaped in half.
Old 10-24-2009 | 04:24 PM
  #846
Ouch! The Serpent metal is very hard but that can make for a brittle piece. I have not broken any parts yet except for two of the hardened optional diff rings. Those will shatter like glass they are so brittle!!!
Until you get a replacement slider, you can just put longer 3mm set screws through the aluminum slider and use those to set the T bar tweak. I sometimes do not use my blades. As for the shock shaft, not much you can do there except get another.
Crashby is offline
Old 10-24-2009 | 04:37 PM
  #847
+1.. this week also..
kdempsey is offline
Old 10-26-2009 | 06:24 PM
  #848
got my new slide bars today and they were the revised ones, now just waiting on the mono shock shaft.
Old 10-26-2009 | 06:53 PM
  #849
KostaG's Avatar
How can you tell the difference between the old one and the new revised one?
Thanks.
KostaG is offline
Old 10-27-2009 | 07:21 AM
  #850
Thanks.
the old ones have groves on the bottom side and the new ones just have lines on top side no groves to make it weak.
Old 10-27-2009 | 10:16 AM
  #851
HarryN's Avatar
When is the 1s LiPo conversion going to be available for the S120?
HarryN is offline
Old 10-27-2009 | 10:33 AM
  #852
CarbonJoe's Avatar
Regional Moderator
The last I heard was that there won't be a conversion kit, since so many things have changed (chassis, rear pod, etc.) The front end is the same, though.
CarbonJoe is offline
Old 10-27-2009 | 10:46 AM
  #853
HarryN's Avatar
Ahhh crap. Now how am I going to sell this damn thing. I have an unbuilt kit I got in a trade.
HarryN is offline
Old 10-27-2009 | 12:26 PM
  #854
chris moore's Avatar
Not so fast, Gavin at Speedzone is working on a saddle 1s lipo. I've trial fit the dimensions of the pack on my 120 and it will fit so there is a viable lipo comming for the t-bar owners, just dont know when it'll be avalible.
chris moore is offline
Old 10-27-2009 | 02:28 PM
  #855
radio_car_racer's Avatar
Prototype has won the modified class at R1 of the European Pan Series
http://www.serpent.com/news/12824/Ge...120/S120L.html
radio_car_racer is offline
