Old 06-22-2009, 11:43 PM   #811
Originally Posted by odpurple View Post
Wha???!!?
Except me when you are passing
I think the key word there is passing. If you slow guy's would just learn that when a faster car is coming up on you, you don't go into the weave mode, the world would be a happier place.
You better get back to packing Futons or you might have a front yard full of angry customers camping out in your front yard sleeping on their Photons.
Crashby is offline   Reply With Quote
Old 08-02-2009, 07:54 AM   #812
rack's Avatar
Trader Rating: 65 (100%+)
Have any body seen or heard any thing about the s120L chassis that was coming out. The last time I asked they were very ruded but I spended alot of money on this car and it is not lipo friendly I would like a asker.
rack is offline   Reply With Quote
Old 08-02-2009, 08:23 AM   #813
kschu's Avatar
Trader Rating: 16 (100%+)
Send a message via MSN to kschu
i thought this thread is dead jus like S400...
Give the best while u can !
kschu is offline   Reply With Quote
Old 08-02-2009, 11:13 AM   #814
Company Representative
Gavin Creado's Avatar
Originally Posted by rack View Post
Have any body seen or heard any thing about the s120L chassis that was come out. The last time I asked they were very ruled but I spended alot of money on this car and it is not lipo friendly.
Just wait for our 1S lipo saddle pack. Keep you existing chassis.
Speedzone Lipo Packs & Brushless Motors - It's all About Performance! - www.speedzoneUSA.com
2017 Canadian National Champion//2016 ROAR National Champion//2016 Canadian National Champion//2012 ROAR National Champion//Region 5 Champion//2011 Cleveland Indoor Champions
Gavin Creado is offline   Reply With Quote
Old 08-03-2009, 01:33 AM   #815
This thread isn't dead, we are working on things ;-)
Speedtech RC Germany-Home of MobGums tyres
--------12scale addicted---------
Mr. Blonde is offline   Reply With Quote
Old 08-03-2009, 09:26 AM   #816
Carl Giordano's Avatar
Trader Rating: 24 (100%+)
HURRY UP ALREADY
Mugen Racing / OS Engines / KO Propo / Byron Fuels / Schuur Speed Motors / AKA / Bruckner Hobbies / Tamiya M-Chassis / Kyosho / Yokomo / 360v2 Raceway / Cruzin with RC
Carl Giordano is offline   Reply With Quote
Old 08-03-2009, 09:44 AM   #817
Marcus. Just sent you a PM.
Old 08-04-2009, 03:16 PM   #818
Arno's Avatar
Default S120 for sale
http://www.rctech.net/forum/r-c-item...ies-parts.html
Arno is offline   Reply With Quote
Old 08-12-2009, 07:40 PM   #819
tl2111's Avatar
Trader Rating: 21 (100%+)
Send a message via MSN to tl2111
Anyone havng trouble with the pivot ball, it seems way to tight when lock the screw and when you untight the whole socket is moving????
*Tourer**Futaba***SpeedPassion
*F1**4PX***TORO
*12th**4PX***TORO
*8th**4PX***OS Speed XZ-R
*10th**4PX***OS Speed XZ
tl2111 is offline   Reply With Quote
Old 08-12-2009, 11:04 PM   #820
Geezatec's Avatar
You're useing the stock King-Pins?? They maybe too long. Tightening down the king-pin too far may bind the steering block oval, not round like it suppose to. Loosen the king pin till pivot is free, not binding. Make note how many turns you loosen the kingpins.. Remove king-pin completely and dremel the access off, could be 2mm. Then tighten adjusting nut(411048) to where in moves freely.
You must have purchased one of the first model tat came out. Newer models have been upgraded since.
Good Luck!!
Geezatec is offline   Reply With Quote
Old 08-13-2009, 12:59 AM   #821
tl2111's Avatar
Good Luck!!
Thanks Geezatac,
What I ask is about the T-bar pivot ball, I cant get anywhere near the smoothest that I get from Asso, CRC type pivot ball system.
*F1**4PX***TORO
*12th**4PX***TORO
Old 08-13-2009, 03:22 AM   #822
kenobi's Avatar
Trader Rating: 17 (100%+)
Default Front wheels
Hi,
Just finished building my s120 - found the issue with the king pins being too long and adjusted by screwing them in a touch. However now when I mount the wheels and tighten the nuts, the wheels do not turn freely.
Is this somehow caused by the kingpin being too long? Or is it something else entirely?
kenobi is offline   Reply With Quote
Old 08-13-2009, 03:34 AM   #823
AndiF's Avatar
What do you mean by "when I mount the wheels and tighten the nuts"? How far are you tightening? The nuts should only be tightened to the point where the wheels still spin freely. So just losen the nut a bit until the wheel is spinning freely again...
If it's not about the nut being too tightened, check if the kingpin is not touching the inside of the wheel (this you might have to check anyway...)
Rgds,
Andy
Team Durango Switzerland - Corally - CRC - IRS - Team Associated
AndiF is offline   Reply With Quote
Old 08-13-2009, 09:04 AM   #824
Geezatec's Avatar
Thanks Geezatac,
OK! No problem!! Putting it together by the manual it would always be loose. To tighten the action of T-Bar, Just reinstall Part# 411051, so the allen screws( adjustment scews) point to the rear of car. Then go from therefor adjustment. You should be alright.
Good luck!!
Old 08-13-2009, 09:19 AM   #825
Geezatec's Avatar
Originally Posted by kenobi View Post
Hi,
Being a Serpent fan since '85, You get use to problems like that. Length of kingpins. You'll see theads of KP are left tightening them down, and later see that it has NO clearance, for the wheels to turn, Wheels bind up with KP. When tightening on Steering block it pinch the pivot, binding it up. Just use mechanical know how to make it work. It's all in the hobby!! lol!!
Since the Front axles are stationary, just Tghten the lock nuts that it turns freely. You ok with it. It won't come loose.
By the way!!King in assembly I really don't like the front spring to ride against the E-Clip. I used a left over spacer, fron the servo savor B/N the spring & E-clip.
Have fun fellow Serpentiers!!!!
Serpent 710 Ron C. Nitro On-Road 23347 03-16-2010 02:47 PM
