Old 11-10-2009, 06:37 PM   #871
Send a message via Yahoo to motojon
Originally Posted by Crashby View Post
If you are using a JR 3550/3650, it should fit perfectly with the servo output shaft dead middle of the chassis. The kit comes with four servo mounts. You have to use a combination of the four to mount different sized servos. I use the JR 3550/3650 and the output shaft is right on the center line of the chassis. To get it centered, you do have to mount the servo biased towards the right side of the car.
Thank u I'll give it another shot
I forgot to ask. Is it a carpet or asphalt track?
Its a asphalt track
My Gpa(RIP)
motojon is offline   Reply With Quote
Old 11-12-2009, 02:53 PM   #872
Also what are the eccentrics in the rear pod supposed to do
My Gpa(RIP)
Old 11-12-2009, 03:12 PM   #873
corallyman's Avatar
Trader Rating: 99 (100%+)
They are used to raise or lower the rear axle. When your tires are bigger in diameter you would use a eccentric spacer that would locate the axle more to the middle, as your rear tires get smaller you would put in an eccentric where the axle hole is lower. This changes your rear ride height. If this is not what you meant then disregard everything I just said
Steve
Team ORCA / ORCA USA / Pro Spec
Serpent America / Team Serpent S411 ERYX / On Point Racing OP12C, S120 / Xceed Products
Hangar 30 / Seattle RC Racers
Fasttrax Racing Series / NORA On Road Series
corallyman is offline   Reply With Quote
Old 11-12-2009, 04:22 PM   #874
Sounds good to me
My Gpa(RIP)
Old 11-13-2009, 10:54 AM   #875
Regional Moderator
CarbonJoe's Avatar
http://www.serpent.com/news/12866/Sc...S120-Link.html
*** The Gate - Celebrating 8 years at the same location ***
The difference between genius and stupidity is that genius has its limits. - Albert Einstein
Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car
CarbonJoe is offline   Reply With Quote
Old 12-10-2009, 09:16 AM   #876
radio_car_racer's Avatar
S120L
pics on facebook
radio_car_racer is offline   Reply With Quote
Old 12-10-2009, 12:35 PM   #877
RC MARKET's Avatar
Good !
RC MARKET is offline   Reply With Quote
Old 12-15-2009, 12:45 AM   #878
Taz_S's Avatar
Here you go guys that do not want to buy a new car.
Originally Posted by Gavin Creado View Post
Hi All,
Finally getting close to the release of the packs. It's been a long wait and thanks to all for your patience. I estimate about 10 days until the packs are available.
Here are the details and pictures of the packs:
Speedzone 1S Raised Bullet Pack
Mah Rating: 5000 mAh
C Rating: 40C
Maximum Charge Rate: 5C
Volts: 3.7v
Speedzone 1S Raised Deans Connector Pack
C Rating: 40C
Volts: 3.7v
Speedzone 1S Standard Pro Pack
C Rating: 50C
Volts: 3.7v
Speedzone 1S Saddle Pro Pack
Mah Rating: 5200 mAh
C Rating: 50C
Volts: 3.7v
Jake's Performance Hobbies http://www.jphracing.com/
https://www.facebook.com/groups/757500284356171 Facebook Group for Pro 10
Taz_S is offline   Reply With Quote
Old 03-14-2010, 02:57 PM   #879
Trader Rating: 29 (100%+)
Default set up speed zone
does any one have a set up for the new 1s saddle from speed zone 17.5 brushless for asphalt
thanks ronnie
ronzo is offline   Reply With Quote
Old 11-18-2010, 06:53 PM   #880
gearhead_22's Avatar
Send a message via AIM to gearhead_22
having problem grttin my servo to line up in the center
serpent sdx4 srx2 977WC-novarossi-748TQ
serpent S120 LTR-S411
serpent America/Ashford Hobby/skyrocket racing
Juwan Hunter
gearhead_22 is offline   Reply With Quote
Old 11-18-2010, 07:33 PM   #881
chicky03's Avatar
Send a message via AIM to chicky03
Do you have the link or tbar version? and what servo?
Take a picture of your chassis and post it here so I can see what version chassis you have.
Serpent America, Picco, Desoto Racing, Motiv, J Concepts, Nitro Pro fuel, PT RC Racing Oils, TQ Wire(best wire ever!), BSR tires, Arrowmax, Xceed, Sanwa, Amain Hobbies, MIP, Getcustomized, EZ Customs
chicky03 is offline   Reply With Quote
Old 11-18-2010, 08:39 PM   #882
I have the t-bar car jr 3650
SERPENT 120-s120-under.jpg   SERPENT 120-s120.jpg   SERPENT 120-serpent-s120.jpg
Juwan Hunter
Old 11-18-2010, 09:34 PM   #883
chris moore's Avatar
Trader Rating: 88 (99%+)
As mentioned earlier in this thread you will need to try different combos of the mounts, I'm using a Futaba 9650 and it took some trial and error to get the right combo of mounts.
Sponsered by:
CMDezigns Paint Works
https://www.facebook.com/pages/CM-Dezigns/259989190822177?ref=hl
chris moore is offline   Reply With Quote
Old 11-19-2010, 07:25 AM   #884
as you can see from the pic i have all four mounts and i was there for over an hour swapin mounts i an lost.
Juwan Hunter
Old 11-19-2010, 07:46 AM   #885
avs
avs's Avatar
is this an older chassis plate?
the second batch (late 08') of s120 kits had both sets (left and right) holes drilled for futaba offset. if you have one of these kits you will need to drill one hole. see posts 558 and 562 for my experience.
i am certain that later chassis were corrected.
Tony Shimko
avs is offline   Reply With Quote
Serpent 710 Ron C. Nitro On-Road 23347 03-16-2010 02:47 PM
