Go-Tech Engines Thread
#8207
good to see ya made it home safely mate and hope ya didnt break nothing did well mate look foward to the setup sheet and hopefully next time new radio sytem may fix my problem i had but was fun racing with u hope ur servo
did make it throught this event
#8208
From reading that Shimming 101 article this is what I gather for my application (Losi 8ight 1.0 with a GO 3 port sport,Dynamite 086, 20% nitro)
Either no shim or a .1 shim for a total of .4mm
Medium Hot plug, running an OS #8 (medium) right now. Sounds like I need to try a #7?
Any thoughts?
Any thoughts?
No shim? that won't work.
Rex
#8209
was good mate i will send the set up to you , my car omly ate 2 servo this weekend i put a new in for the final , i might be changing brands of truggies and buggies as im sick and tired of the on going steering servo problem that can not be rectified i could have bought another truggy by now
#8210
rather then saying it will not work why not tell him why it will not work ? with no shim in you have .3 of squish adding 1 .1 will give a total of .4 if your only running 20% a .1 shim may all that be needed ...
IMO i would just run .2 shim give you a toatl of .5 med hot plug
#8211
Finally got my gen 4 7 port(with a cut lsn) dialed in correctly, never flamed on me once all day came in at 7:30 with at least a third of a tank every stop.
6mm restrictor, od 97t plug, one brass one silver shim, werks medium conical with dynamite 053 pipe.
Almost had TQ and won the main not bad for only three times out in the last year
#8212
good job mate , i have tried the shorter lsp but have gone back to the long lsp needle but its a personnel thing thing i guess
in my truggy with the 7 port gotech i have been pitting in around 12 min still with fuel in the tank , maybe i might stretch it alittle further
#8213
#8215
i ran my 5port with .7 shims and p3 plug & 30% sidewinder this wknd, the motor wouldnt run good under 270s and not good there. i had 1.0mm shims in until i read the shimmin article and i pulled .3mm shims out and the motor was insane and would run at 220 but started flaming on me after a while, could it be the hot plug with the 30% ??
#8216
Here ya go, guys & gals!
MG66
http://www.massivemods.com.au/produc...roducts_id=244
MG66 Ceramic
http://www.massivemods.com.au/produc...roducts_id=245
MG66 Combo
http://www.massivemods.com.au/produc...roducts_id=246
MG66 Ceramic Combo
http://www.massivemods.com.au/produc...2d39be9b728535
Pete
MG66
MG66 Ceramic
MG66 Combo
MG66 Ceramic Combo
Pete
#8219
2Likes
