Like Tree2Likes
Go-Tech Engines Thread
Old 08-10-2009 | 01:30 PM
  #8206
mattwoodcraft's Avatar
in my go techs i use the go tech plug T3 which is a hot plug most of the time at the moment i have been using a OD97 med plug as i run 30 % nitro
mattwoodcraft is offline
Old 08-10-2009 | 03:09 PM
  #8207
mrbusta's Avatar
Default hey
good to see ya made it home safely mate and hope ya didnt break nothing did well mate look foward to the setup sheet and hopefully next time new radio sytem may fix my problem i had but was fun racing with u hope ur servo
did make it throught this event
mrbusta is offline
Old 08-10-2009 | 03:16 PM
  #8208
22Racer's Avatar
Originally Posted by cLaWz
From reading that Shimming 101 article this is what I gather for my application (Losi 8ight 1.0 with a GO 3 port sport,Dynamite 086, 20% nitro)
Either no shim or a .1 shim for a total of .4mm
Medium Hot plug, running an OS #8 (medium) right now. Sounds like I need to try a #7?
Any thoughts?
No shim? that won't work.
Rex
22Racer is offline
Old 08-10-2009 | 03:18 PM
  #8209
was good mate i will send the set up to you , my car omly ate 2 servo this weekend i put a new in for the final , i might be changing brands of truggies and buggies as im sick and tired of the on going steering servo problem that can not be rectified i could have bought another truggy by now
Old 08-10-2009 | 03:23 PM
  #8210
Rex
rather then saying it will not work why not tell him why it will not work ? with no shim in you have .3 of squish adding 1 .1 will give a total of .4 if your only running 20% a .1 shim may all that be needed ...
IMO i would just run .2 shim give you a toatl of .5 med hot plug
Old 08-10-2009 | 03:51 PM
  #8211
HaulinBass's Avatar
Finally got my gen 4 7 port(with a cut lsn) dialed in correctly, never flamed on me once all day came in at 7:30 with at least a third of a tank every stop.
6mm restrictor, od 97t plug, one brass one silver shim, werks medium conical with dynamite 053 pipe.
Almost had TQ and won the main not bad for only three times out in the last year
HaulinBass is offline
Old 08-10-2009 | 04:02 PM
  #8212
good job mate , i have tried the shorter lsp but have gone back to the long lsp needle but its a personnel thing thing i guess in my truggy with the 7 port gotech i have been pitting in around 12 min still with fuel in the tank , maybe i might stretch it alittle further
Old 08-10-2009 | 04:36 PM
  #8213
22Racer's Avatar
Rex
The shim is softer than the head button or the sleeve and acts like a gasket.
In your setup I would run 1 alum and 1 thin brass or even just the aluminum.
Rex
22Racer is offline
Old 08-10-2009 | 05:00 PM
  #8214
Default GO .25 turbo button
I have 2 new ones, but I don't like to ship outside of the Us. Last race my son ran his .25 with the turbo button and a shim added for a little timing and it was a rocket.
Rex
I'm intersted on the GO .25 turbo button.How much are you selling it?
nitro64 is offline
Old 08-10-2009 | 05:05 PM
  #8215
i ran my 5port with .7 shims and p3 plug & 30% sidewinder this wknd, the motor wouldnt run good under 270s and not good there. i had 1.0mm shims in until i read the shimmin article and i pulled .3mm shims out and the motor was insane and would run at 220 but started flaming on me after a while, could it be the hot plug with the 30% ??
randystang is offline
Old 08-10-2009 | 05:35 PM
  #8216
Blackie001's Avatar
Here ya go, guys & gals!
MG66
http://www.massivemods.com.au/produc...roducts_id=244
MG66 Ceramic
http://www.massivemods.com.au/produc...roducts_id=245
MG66 Combo
http://www.massivemods.com.au/produc...roducts_id=246
MG66 Ceramic Combo
http://www.massivemods.com.au/produc...2d39be9b728535
Pete
Blackie001 is offline
Old 08-10-2009 | 05:44 PM
  #8217
Nearly blew up the computor with all the drool
What is the power band,is it in between a 5port and 7port?
ben1970 is offline
Old 08-10-2009 | 06:10 PM
  #8218
22Racer's Avatar
I heard Russell is getting a couple Mg66's in the states for testing.
Rex
22Racer is offline
Old 08-10-2009 | 06:28 PM
  #8219
Blackie001's Avatar
A HUGE amount more than a standard go engine. These are made to Marks Specs. An Animal!!!
Wood!
Old 08-10-2009 | 08:45 PM
  #8220
Is it normal for the carb to rotate slightly after the retaining bolt is tightened i mean REALLY tightened ? if not normal then can someone tell me what do I need to do to fix this?
TopGearRC is offline
