Trinity EXTECH .21
Old 07-27-2009 | 09:48 AM
  #1801
What carb restricters you guys using and who makes them for this engine?
I am ising the 053 pipe and makes great power but guzzles the gas.
brian kadow is offline
Old 07-27-2009 | 10:19 AM
  #1802
KThatcher's Avatar
Any Sirio Based restictor will work (werks,Orion alpha)... Try using the 086 pipe for a little better fuel consumption.
KThatcher is offline
Old 07-27-2009 | 04:50 PM
  #1803
i have a .24 racetune engine .it runs real lean on bottom at stock needle settings.it is at about twelve hours out some stock.i am getting ready to throw this piece off .... a way .you movethe low end out one hour it runs lean. i have sealed the engine.i am lost with this engine.
AETRUGGYMAN is offline
Old 07-27-2009 | 06:59 PM
  #1804
ngo8's Avatar
are you ruuning it in a truggy ? which one maybe its not the motor and maybe its the gearing i found that this weekend my mugen was under geared i went up 2 teeth and fixed all the problems .give it a try .
ngo8 is offline
Old 07-28-2009 | 08:21 AM
  #1805
Huh? What does the gearing have to with whether an engine is lean or not?
cjtamu is offline
Old 07-29-2009 | 10:42 PM
  #1806
DRRC's Avatar
I just got a second Extech 2 raced tuned yesterday
When I started it today all the settings on the carb were wrong
it was righ and the HSN and LSN were sticking out
I tried the rich settings and still would not work well, very rich
What can I do for this engine and what settings
I am using a dynamite HS pipe, odonell 77 plug, 30% fuel
My first extech race tuned was right on and have not touched the setting since getting it a few months ago with the same pipe, plug and fuel
DRRC is offline
Old 07-30-2009 | 07:19 AM
  #1807
David Wall's Avatar
Are you saying you have been running the engine for months at the break in settings? THe FM and RT models have been run on the bench with break in setting on the carb, you should have to go in SEVERAL hours on the HSN to achieve race tune. What temp is it running at?
David Wall is offline
Old 07-30-2009 | 08:46 AM
  #1808
DRRC's Avatar
Yes I have
The first Extech race prepped engine that I have not touched the settings on was EB mod, Ed Bridges, modded and race prepped hence the carbs were set to his dyno tune. I had an email from chad saying he now breaks in the Extechs now and leaves the carb rich. My contention is if it is broken in and race prepped dyno tuned it should have the settings that it was tuned with, why reset the carb and make it rich? I have 2 EB Mod engines and put it in the car and break in 20 mins and then race with the same settings
I am disappointed bec I thought it would be the same Extech .21 race tuned engine like I had bought before. So spent more money on just being broken in, tuned and reset to rich, this does not help me and this is not what I expected hence the frustration right now. Evenmore bec I have a big ROAR race this sat where I will drive 2 1/2 hr to race this engine but will be breaking it in and tuning it over there
EB mod engine that were dyno tuned were very crisp and fast, I did not even dare to touch the settings because they were like butter, I could not do a better job if I tuned it myself for a few weeks.
So what are a good starting point for this engine. I tried the rich settings in the instructions and was still way off, tried the tuned settings and were too lean, so I am at a loss right now. Temp was 220 after running half speed 5 mins.
DRRC is offline
Old 07-30-2009 | 10:43 AM
  #1809
David Wall's Avatar
My FM 21 when I ran the Dyn 086 pipe ran 180-190 no matter where I ran it. I am not sure as far as how many turns in or out on the needles, I tune mine by feel on the track, and just check temps for a piece of mind I guess. As long as I get smoke coming out of corners and at end of longest straight, I am good with it. I did change this past weekend to the big boy pipe and had to lean the HSN 8 hours, but still came off after main at 192 degrees. This is in my Trinity Extech 2, I have the new Epic version sitting in my pit bag just screaming to go play I will say the big boy pipe WOKE THIS MOTOR UP big time, but I did loose fuel milage, which should not have happened, going to spend a little more time tuning and see if I can get milage back. I was getting around 10min a tank with the 86pipe.
Old 07-30-2009 | 10:55 AM
  #1810
chevydc44's Avatar
What is the best pipe to use with the extech 2? I run a rev so it's a large track i tried different pipes the big boy, 086 didn't like either one
chevydc44 is offline
Old 07-30-2009 | 11:59 AM
  #1811
KThatcher's Avatar
I race at Revelation aswell and run either the 2013 in my buggy and 086 in my trugggy.. if you dont like the 086 try the sirio 2057... or 2058
If you ever neeed any help with the engines you can either ask me for some help. just find me Blue and Orange D8 with an ex-tech
Old 07-30-2009 | 12:24 PM
  #1812
chevydc44's Avatar
Cool thanks yeah i like the motor it seems to run pretty good i just put on a ttr2035 and it seems like it has alot of snap and it idles really good that is a bottom end pipe we will be there on sunday so if you want to come out we will be there they just did a new layout it's pretty fun
Old 07-31-2009 | 03:57 AM
  #1813
HI Everyone,
It has been a wild and crazy summer with the move. I wanted to apologize about not answering some of your guys emails and taking care of some of the problems as quickly as I have in the past. we went a fair amount of time without engines or parts and I have more responsibility which has hurt my CS time.
Currently everything is back in stock and im catching up on backorders. The new engines are great and run better than before. A couple of the upgrades are new crankcase that has a lower cg, new head, and carburetor with a better fitting orings. no more loose lsn.. also they weigh less
on another note. This is something most people dont think or realize when they are installing the clutch. sometimes cranks have a small amount of play. When installing your clutch, pull the shaft out as far as you can before installing cone washer and flywheel. By doing this it
1) prevents the rod and crank pin from wearing on the back plate
2) prevents premature wear from the rod bushing and crank pin as it wont move around during operation
Thats it for now,
TTYL
Chad
Chad Phillips is offline
Old 07-31-2009 | 04:06 AM
  #1814
oh pipes and inserts
1) I only run Big boy on a .21 FM with 5.5mm restrictor. i can get 11minutes a tank everytime i run my car.
2) I only run a 2057 on a .24 FM with a 8mm restrictor. Same thing 11 minutes a tank..
both with os p4 glow plugs and 30% platinum fuel. Fuel plays a big part on runtime.
Old 07-31-2009 | 08:08 AM
  #1815
Yes I have
It's not possible for them to send you an engine that's "tuned and ready to go" out of the box. Different fuels, different plugs, different pipe, altitude, temp, humidity. All those affect how the engine runs. Hell, you have to retune the same engine when the weather changes. If you got one before that ran without you touching the needles, that was just a stroke of luck. Tune the new one and let it rip.
cjtamu is offline
