Trinity EXTECH .21
#1051
ran another two tanks today ruch settings friday i plan to lean alittle and run two more. nothing unusual idles all day long no problem though. I open the idle screw 1/2 turn during start up let it sit 30 - 45 seconds short blips to warm in up a little and once it warms return the idle screw to its original setting, once its warm it will idle for minutes with a little hicup under aceleration. I'm gonna lean the top a little and let er rip!!
#1052
just started to break in my Extech using trinity medium plug. it would idle for about a minute then the revs would go way up. Temps around 230 with sidewinder 20%. I reduce the idle and it comes down a little then after about another minute the revs jump way up again. Am I doing something wrong. Never had this on a break in before. Thanks
#1053
Do you live at a high elevation? I live in WV and the same thing happens here. I turn the idle down about 3/4 turn before I even fire one up for the first time.
#1054
i would think 230 would be to high for the extech? with race tune in the summer around 195 and if i leaned it too much it would go into the 220 range and not run well. just a thought. mine idles all day at 165 yours reving up would seem like a air leak to me? what medium plug?
#1055
I am in Phoenix so alt is no prob. I am using the Trinity medium turbo plug. There is no number on it. I did not hi temp seal the carb or back plate. Should I?
The low speed is set 5 turns out (came from fractory that way) High speed needle is very tight, flush with top of brass fitting. I have been reducing the idle but it is way less than 1mm now. Thanks again
#1058
here is the plug. Trinity number 6
http://www.amainhobbies.com/product_...ducts_id/26711
Frank, I am going to finish break in on Sat. I may call if I have a problem. Thanks
#1060
I WANT TO BUY IN AMAINHOBBIES THE Trinity EB MODS .21 Power Box Kit with Kyosho, Mugen, X-Ray Style Clutch
[trI40201RP] BUT I WANT TO KNOW WHICH IS THE ENGINGE THAT COME IN THIS PACK?
IN THE DECRIPTION SAID EB MODS .21 BUT WHAT IS EXACTLY THE ENGINE OF THESE THREE OPTIONS:
[trI40066]
(TRI40064]
[trI40060]
http://www.amainhobbies.com/index.ph...&filter_mfr=67
THANK YOU.
[trI40066]
(TRI40064]
[trI40060]
THANK YOU.
#1061
The stock numbers should be
060-Stock Ex-Tech Not modded or broke in
064-Race prepped motor Broke in and flow tested
066-Full mod motor basically the same as the 064, but has a full mod on the motor
The Power box you were looking at should have the 066 full mod motor in it.
Hope that helped.
Hope that helped.
#1063
hey jpalessi what exactly lis flow tested I have a general idea but just wanted a detailed explanation what they do and what they are looking for? thanks I'm glad my new extech was a ebmod one! was mad at first but then I thought about it and i was glad.
#1065
THANKS TEUFEL RACING
WHAT DO YOU THING FOR THIS POWER BOX? I WANT MOUNT IN MY MBX6
ONE FRIEND BUY ONLY THE FULL MODED .21 ENGINE BUT IT COST $465 IN AMAIN, THIS PACK COME WITH PIPE AND CLUTCH, WHATH DO YOU THING FOR THE PRICE.
IF THIS POWER BOX COME WITH THE 066 FULL MOD IS GOOD PRICE.
