Trinity EXTECH .21
Old 12-04-2008 | 10:54 PM
  #901
My ExTech is leaking alot around the carb, I mean alot...almost streaming out around the carb or carb boot. I sealed the carb with Lucky 7 and it still leaks, I removed the carb boot and very carefully cleaned eveything and made sure it was seated perfect but haven't tried it yet to see if that helps. It's also getting very notchy in the cold weather, everything is fine then from one heat to the next the top hits hard and it's difficult to drive. I have to richen the top alot to calm it down. I don't dislike the motor I just wish it didn't leak so bad and wasn't so notchy. I haven't had these problems with my Novarossi or even my low budget VG.
KyJoe340 is offline
Old 12-04-2008 | 11:02 PM
  #902
jpalessi's Avatar
jpalessi is offline
Old 12-05-2008 | 12:04 AM
  #903
Thanks, I'll check that. It's not wet on the boot itself but at the base of the boot and below the carb, and only on the boot side of the carb. The other side is dry.
KyJoe340 is offline
Old 12-05-2008 | 12:14 AM
  #904
jpalessi's Avatar
jpalessi is offline
Old 12-05-2008 | 07:09 AM
  #905
TEUFEL - shipped yours back yesterday! looks good put notes in there
KYJOE - if you sent it back and ill take care of it!
Chad Phillips is offline
Old 12-05-2008 | 03:12 PM
  #906
speedy2's Avatar
I run a TTR pipe of amain 2035 or something at 30.00
and P3 os plugs
speedy2 is offline
Old 12-05-2008 | 03:25 PM
  #907
Thank you, I'll do that. Chad, could you PM me with your work number and I'll call you monday to get shipping info. thanks again
KyJoe340 is offline
Old 12-08-2008 | 09:58 AM
  #908
I have 2 packages here with no return address. They both came from shipping stores.. One package is from Illinois and the other from Virginia.. contact me at [email protected] to identy your item so it can be returned to you. thanks
Old 12-08-2008 | 11:39 AM
  #909
PinoyCali's Avatar
I just got my extech 21 pre -run .. But im having problem pulling the carb out to tight . ...Pull turn pull turn...
PinoyCali is offline
Old 12-08-2008 | 11:40 AM
  #910
You can send those both to me Chad
C Branch is offline
Old 12-08-2008 | 11:54 AM
  #911
pinoy - check the clinch bolt.. it may be tight
Old 12-08-2008 | 12:07 PM
  #912
PinoyCali's Avatar
no its not i took the right side off.. Im almost there half way
Old 12-08-2008 | 12:09 PM
  #913
do you have both sides loose? i know on other engines if i leave one side tight it will still be stuck, i usually have to press in when i am threading the bolt out to get the other side to come out
cjm1126 is offline
Old 12-08-2008 | 12:23 PM
  #914
PinoyCali's Avatar
I pushed it out a little bit.
Finally its out ..... I cant wait to go home lols
Old 12-08-2008 | 12:33 PM
  #915
whats the best pipe for the .21 eb modded? hows the new 2056 compared to the 2013, 086 etc. power and runtime thanks
franklucas is offline
