Trinity EXTECH .21
#1651
8 or 9 tanks. The linkage is good on it. Based on today I think I have a serious problem. I took the time today to really focus on just getting it tunned with no luck. No matter which way I turned the needles the same thing would happen.
I tried every combination 1 hour at a time one at a time. It continues to make the same noise with the idle going high then going low and girgiling off throttle no matter what I do. In fact the more I got into it the worse it became.
Off throttle the only way I can explain the noise is like a high pitched girgiling noise that sounds like is blubering and its loud. Its not a normal noise and becomes worse when it hits operating temps. No matter what I did it didnt make better or worse but more worse. The noise sounds like a clunker of an engine.
At $360.00 I am pissed!!!!!!!!!!!!!!!!!!!! I havent done anything to cause this problem no serious crashes nor have over temped it.
I am stuck!!!!!!!!!!!
#1656
Originally Posted by Jaz240
Try different fuel Dish, you may have a bad batch
How common is it to get a bad batch of fuel. I started thinking about this and here is what I have come up with. If you remember my first post when I started having problems I stated that the week before it was perfect during practice and had zero problems breaking it in and running it during a practice session.
I started having problems on race day two Saturdays ago and have had problems ever since. Two Saturdays ago is when I bought a brand new gallon of fuel. In fact I didnt even show up with the last gallon that I had becuase I used it all up during the practice that I had when it ran great.
Since the get go of this new gallon of fuel I have had problems. I also started thinking about my sons 1.0 during race day. I had his buggy set up perfect and it flammed out a couple of times during the races which never happend to me in the past before handing it down. I also had to play with his idle in between races as it was higher than normal. I also had to replace a glow plug in his that was fairly new. We were both using the same new gallon of fuel.
Jaz and everyone else, this could be it. I am hoping that this is the problem but questioning how often this could happen. I am going to order some stuff online to test it. If I buy another gallon from hobby town I could possibly run into the same problem if it is a bad batch. At least this is one other thing that I can eliminate if its not the problem.
#1660
Ok guys here is the new theory. Jaz mentioned this in my local thread and here is how I responded. What does everyone think of this theory!!!!!!
cheezy91, you can use a go tech carb boot if your in a pinch, just use some engine sealant on it and zip tie the big end, its a bit narrower on the big end and using the zip tie spreads it out a bit and works fine.I actually liked the go boot a little better than the stock cause its a better and thicker rubber and doesn't tear so easily.
#1661
smracer, got the head button today. Thanks a million.
Pinoy, try a Werks or other Sirio head with the same bolt pattern. I've heard they work. May not run just the same but should get you through till you can lay hands on another Extech head.
#1662
Thank you very much ... I will wait for Chad to reply e-mail till friday if not I will buy the sirio .21 head.
#1663
....... Anybody using aftermarket or diff. brand cooling head?...
