Trinity EXTECH .21
#1681
There is an RC god!!!!!!!
I figured out the noise that my engine was making. It wasnt the fuel because I got some new fuel today and it was doing the same thing. I do have another problem now but I think this one everyone will be able to figure it out much easier.
Are you ready for what the problem was? Drum roll!!!!!!!!!!!!!
The low speed needle was to lean. LOL. I dont know why I did this but I just gave the low speedle needle two full turns out from frustration and the noise went away. Reset my idle threw it on the ground and no more noise.
Here is what I am facing now.
I richened it to where there was very little power and it would flame out. I leaned the LSN 1 hour at a time until it ran consistently with no flame outs. As I kept leanning 1 hour at a time the power on the low punch would not get better. It felt gutless. I kept leanning and the noise came back so I richened it just under where the noise would stop.
The engine is not making great power now. What should I do next? Another thing I noticed was no matter where I move the lsn the same amount of smoke would come out whether it was rich or lean?
#1683
Go to: www.teamepiconline.com
#1689
dishsoap I faught with my .24 on tuning . first set the idle gap where the gap is a small as you can.5 mm (barely cracked). Make sure your hsn is flush at the top of the housing and the lsn is flush (both will be rich). set the low speed frist get the motor to idle with the lsn. set it on the ground my sure engine is warmed up and pull a couple hole shots. lean engine on lsn till it has a good punch. then lean the hsn til it runs though the rpm range. you my have to richin the bottom a little. but not much. try it at this point you have nothing to lose. these motors a picky about the lsn and the idle gap. once you get it set your done. hope this helps
#1690
One other thing that has not been mentioned. The pipe that you are running, does it have the adapter between the pipe and manifold? If it does than remove it. I know when I first bought my .24 and the trinity pipe with the adapter it would gurgle like crazy and had no power. Chad told me to remove it and wala it had power and ran like a totally different motor.
#1691
I have a extech I runned-in ebmods
and noticed a little crunchy noise when moving the piston up
by turning the crank with the hand...could it be one of the the bearingballs already?
only have 1 1/2 gallon on it...
#1692
Ran the .24 FM today and realized something, the Big Boy is NOT the pipe for this mill at all. I so struggled with the tune and at best it was flat. I put on a TTR 2035 and you wouldn't believe the difference. Idled better, tons more snap and better top end. All around so much better. I have a Big Boy for sale from the first shipment that doesn't break the baffle off if anyone wants it.
#1693
So other than the trinity pipes and the big boy what is the best pipe for the .21.
Oh I think I have my problems figured out hopefully.
I think it was a combination of three things.
I had some help at the track getting it tuned and kept losing the tune. Just when I though it was perfect on the first race I had to go full throttle the entire way just to make it around the track. I think the motor just magically broke in. Pulled it off leaned a little on the high end and BAM!!!!!! Ran like a champ.
The second isusue was I had a wahser that was resting on the front of the flywheel that was not suposed to be there causing slight drag on the clutch bell.
The last one was my rear break linkage lever pin was sticking and would not completely disengaged after I released the breaks causing drag. I backed out the two top plate screws slightly and the problem went away.
Fixed all of these and ran like you wouldnt beleive until I stripped the plastic servo inserts on my steering. I am begining to learn that these engines need alot of attention when tunning and they are not that easy to tune. It took over 30 min from a guy who is very experienced to finally get it.
If I swtich to 30% fuel should I move the needles. If so how much.
#1694
#1695
You may want to try a different clutch setup. I have been running the 09' .24 FM for about 2 gallons now. Started on my RC8T and now it is on my MBX6T. I run the M2C four shoe clutch with four soft lites and four .9 springs and my RC8T and MBX6T will clear most tripples that the buggies at my track struggle on...
I always start adjusting from the top to the bottom, and set my idle between .5-1mm gap. Reason being is if you set your lsn first, it leaves you with a smaller cushion when adjusting the hsn. So, leave your lsn very rich to the point it just idles without stalling. Slowly lean the hsn until you fail to see anymore performance gain(very little smoke maybe visible), then richen1-4 hours if the performance drops off slightly you know your close to the optimum hsn's setting. When your happy with the way it performs on the top end then began with the lsn. This ensures you are getting the most performance out of the mill before it starts to get hot. if you start from bottom to top you may end up with a mill that is to hot before you engine is performing it's best on the top end then you have to go back and readjust the bottom. I usually check my lsn's setting one of two ways. By now your mill should be well warmed. Make a high speed run and bring the vehicle in. Allow the rpm to fall to a low idle, let it sit for about 10 sec., and accellerate hard. If it hesitates, it is to rich, next i will make a couple laps around the track then bring it in again and imediately pinch the fuel line as close to the carb as possible. The engine should idle normally for a couple seconds then begin to lean out and stall (if your good enough you can usually catch it before it stalls), this should take maybe 4 seconds. If it stalls imediately or leans out quickly it is to lean.
