8T 2.0
Old 07-08-2009 | 05:50 AM
  #3451
mattwoodcraft's Avatar
good idea Tix leave the rebuild for after the nats mate .....
as for the slop just check your bearings to sometimes depends how much you have the slop can be eliminated a small amount ...
but the cars do work verry well with a small amount of slop all apart of the breaking in period
mattwoodcraft is offline
Old 07-08-2009 | 06:48 AM
  #3452
JAMMINKRAZY's Avatar
Originally Posted by marccaracer
Looking for shims to go between the rear axels and the hexes to take out a bit of slop. Anyone know where to find some?
These
http://carolinasrc.com/Webstore/Scri...idproduct=1795
Are what I use. But like tix said, don't shim them too tight. I only use them when there is an overly excessive amount of play. Some movement is good.
JAMMINKRAZY is offline
Old 07-08-2009 | 07:04 AM
  #3453
Frank L's Avatar
No shims here and the truck drives great. I do have a question about shims in the rear gearbox. I recently replaced the ring and pinion and pit the stock shims back in , 2 on each side. There seems to be a high spot where the mesh gets a little tighter. Do I shim to the highest spot or let it wear in? I have 1-5 min qual and a 20 min main on it and it still has a high spot. Reshim or leave it alone?
Frank L is offline
Old 07-08-2009 | 07:08 AM
  #3454
Default I'm selling my 8T 2.0
I'm tired of playing bumper cars in the truggy class....going 100% buggy. If you are thinking about buying a new 2.0 hold a couple days and let me get the details of this fully loaded truck posted up and photographed. It has three races on it, it is dialed and all the minor issues are already addressed. If anyone is serious, PM me and I will fill you in. I have to find a casio usb cable for my camera, it seems to have walked away on me.
crazysavage is offline
Old 07-08-2009 | 07:10 AM
  #3455
l3asher's Avatar
After about a gallon I had to take one shim out and put it on the other side to get the "high Side" out. Smooth as butter for 3 gallons now.
l3asher is offline
Old 07-08-2009 | 08:51 AM
  #3456
i just sgim my diffs so there are no high spots in it , hasnt given me any problem at all , i think by memory i have 2 one side and one on the other , that with the 2.0 alloy bearing housing too ...
Old 07-08-2009 | 09:56 AM
  #3457
SqueegUK's Avatar
Yep thats it and the magic number is 23.3 mm as per Adam Drake
Oops, just checked mine because they were looking a little thin. Measurement came in at 22.4mm, ouch. Still seemed to work fine though on Sunday. Luckily I have a couple of sets of KHZ 7075 shoes, best I whip those in before the next Nats next weekend.
Also, after the race day on Sunday, there is spilt fuel covered in dust all over the inside of the car and the engine. I guess this is either my pit guy being too liberal with the refuelling or the tank opening when I bin it or both. What do you guys think?
SqueegUK is offline
Old 07-08-2009 | 09:57 AM
  #3458
token's Avatar
if its running fine them probley spilt if you have tuning problems then a leak somewhere
token is offline
Old 07-08-2009 | 10:03 AM
  #3459
Integra's Avatar
Ive had the mysterious tank lid opening BS more then one time....granted its still a 1.0 tank...but i Do have more then a couple bands around the lid to keep it closed......i have a 2.0 tank ill be testing this weekend....but im not convinced its 100% the tank...it all started when i put the 2.0 body on....
Integra is offline
Old 07-08-2009 | 10:15 AM
  #3460
no problems with tanks leaks at all the only time i have had any issues was from the refuels at pit stops bit since using fuel guns im pretty happy alot let mess
Old 07-08-2009 | 10:46 AM
  #3461
Frank L's Avatar
The problem is defiantly with the 2.0 body. I had to just run just the flat part of the zip tie sticking out no fuel tubing and no end on the zip tie, and sometimes in a hard crash it still open the tank. It happens when the truck slides upside down it pulls the tank open. There is a fix to this problem where you add throttle linkage stops to the end of the springs on the tank lid. This helps but it can still open. It will make the lid close better as the springs are now stiffer with this mod. I hope that makes sense.
Frank L is offline
Old 07-08-2009 | 12:00 PM
  #3462
pballer2777's Avatar
i had the same problem with the zip ties. i got the rtr tank lid pulls and i no longer have an issue. $5 for 2 u can't go wrong.
pballer2777 is offline
Old 07-08-2009 | 12:27 PM
  #3463
SqueegUK's Avatar
Thanks guys, I have been having problems getting my V-spec to run right, even put a new carb on, but I am almost sure it is not leaking. I will get it sent off to my mate to check it over. I have an almost new crank case for it to, might get everything changed over to that. Then again, I might just bin it after 2 gallons and just run my new Siim 21 in.
Not been having much luck with engines lately, my GRP tuned was playing up with tune, going rich and lean and then rich again and so on. That's why I threw the V-spec in there.
SqueegUK is offline
Old 07-08-2009 | 01:15 PM
  #3464
+1 on the rtr fuel tank lid puller , they look neater than cable ties to think
Old 07-08-2009 | 01:21 PM
  #3465
Frank L's Avatar
I thought those fancy fuel tank lid pullers would make the problem worse. Good to know they work well. It sucks to lose your gas and then run out early.
Frank L is offline
