Novarossi engines thread
#3286
I do believe the number indicates the strength because the R4 I have seen in older engines as I have seen one in a current offroad engine and the R2 was quickly broken when the N21-3T was tuned up to real performance.
#3287
Please anybody! Are OS or RB turbo glow plugs compatible with Novarossi engines?
I'm waiting for my Toro Nero specially for the nationals, but can't get the plugs in time and the only thing we've got over here are OS's and RB's.
#3288
I run Nova plugs in my RB, so I would say yes. Also, just make sure it's the short plug and you should be fine. One of my RB's came with a Nova 6 turbo plug...I guess that's the answer right there.
#3289
#3290
I was wondering could anyone explain the way the carbon is building-up on the piston and button in the Murnan 35+21 Rex I'm running? And if it's normal?
I'm having a problem with the engine not staying in tune. It can be tuned to run brilliantly, but then will on occasion begin to go rich or lean within the space of a few laps or 5 minutes. Sometimes after letting the engine cool down, and restarting it, (and it being brought back up to normal temperature etc..) it will have gone very rich without anything being different.
On the exhaust port side, there is a lot of carbon which makes sense, but on the opposite side the piston and button get gradually cleaner to the point where there is no carbon build-up at all. It seems strange that there's such a difference.
I've attached photos, but if they're not clear enough let me know and I'll upload new ones. They were taken following 1 days worth of running since the piston and button had been cleaned.
Thanks!
Thanks!
#3293
#3294
#3296
Just picked up a new '09 plus12-3sct. From what I understand the 09 353's rev abit higher, but the plus 12-3sct has better low to mid range power.
What makes them different?
1) Timing on the crank?
2) Exhaust port timing?
3) Transfer Timing?
4) Piston Material (microcast vs billet)?
3) Transfer Timing?
#3297
Does anyone know the reason for the new case on the 353 '09, from the pictures posted all the top Novarossi guys were running with a grey case instead of the black that sells.
Or is it another 353 '09 to come with the original Purple head ?
Balestri
Pietsch
Dirk
Balestri
Pietsch
Dirk
195Likes
