Houstons Engine Service H.E.S.
#541
Hey houston, my Toro Nero came with two aluminum, and two copper shims. This is the non turbo vrs. So my question is there .10 copper shims?
I dont have any calipers, and you mentioned the aluminum would be .30
Oh yeah both copper look to be the same size, and the same with the aluminum..
Im running byrons 30/11
Thanks for any help...
#542
Hey Monty
I hear you're coming down for nitrocross. Awesome. I got a tuning question for ya...
I got this GRP from a buddy of mine, sans carb... so I put a carb off my werks 7port on it. High end is awesome, ran last night at srs, 2 quals, main, practice... 220 degrees each time. My issue is this: low needle and the balance between the two. It runs great, but for some reason after refueling, if I don't pin it for a second, they'll throw it back down, it goes like 10 feet and stalls. Go to restart, and it's flooded. I leaned the bottom out, and it's 80% better. It's perfect all over the track, but at the end of the straight, i take a right hander and it's surging. real high idle speed for a min. Sofar, I've been going in the right direction, i think. Originally it had a rough idle, and we raised the idle stop to keep her going. I think it needs a little leaner low end yet. I leaned it out last night between heat 1 and 2 and it was much better, and dropped the idle stop a little. As I understand it, I keep leaning it out on the bottom a bit more and when it picks up again, drop the idle speed again? Really, it's running great, great power, and PRETTY MUCH reliable LOL... but i don't want it to die after I get pitted, especially if it's gonna be flooded. Last week it took 5 min to get it fired again. This week, it did it only once, and it fired in about 30 sec, so I think i'm headed in the right direction. sound right?
ps: I KNOW, JUST BUY A NOVAROSSI. I will be soon
#543
Hey Monty
also whats wrong with the stock carb?
#544
#545
Hey Monty
p.s. yes
#547
i dont use them personally for the simple fact that it is another place to form an airleak and another item to find a place to mount it . i have seen them in use and noticed a definite increase in power and runtime . cooler fuel definitely makes more power
cooler fuel definitely burns more efficient
combine these two things and there has to be an improvement
#548
#549
hey monty figured i would give u an update. i had a pm from casey peck tellin me my dad ran it to rich and idled to long and it hydro locked then he kept the fuel in there which caused it to be sticky.
he cleaned it all out and it started right up now. but he couldnt get it to stay runnin, i think its to rich so im going to look at it tommrow since im off. he blew our starter box motors due to tryin to start the motor for 30 sec he said. kinda makes me think what the motors in for LoL...
thanks for the help
thanks for the help
#551
thanks for the help
thanks for the help
#552
you did. and i was going to do that. he just provided an explanation lol. like i said thanks ill reintroduce my self when u come for nitrocross
#553
Still gonna buy a novarossi in a bit!
#554
Thanks. GRP carb is missing... out of all the carbs i got, the werks is probably the best shape. i'm using a red insert (not sure what size). like i said, it's all bottom end where my issues are. thought that was a lil warm for GRP. I'll give it a whirl. if not, i'm sure i can find an os carb (thanks Monty!) and maybe play with some pipes....
22Likes
