Like Tree3Likes
Tamiya TRF415
Old 03-25-2009 | 11:43 AM
  #20341
STLNLST's Avatar
Originally Posted by JayL
to droop the tamiya we use the David Jun method:
set car with chassis on setup board, no blocks, no tires, nothing.
measure the distance between the setup board and the top of each axle using the depth measuring part of your calipers
I usually end up with about 26mm in the rear
You racing this weekend? The Tamiya crew will be out in full force.
STLNLST is offline
Old 03-25-2009 | 11:57 AM
  #20342
Csaari77's Avatar
Does anyone know where do get a spool for a 415 msx? I would prefer a Tamiya part to remain TCS legal. Will the unit for the 416 fit in the 415? I've been looking all over online line and haven't been able to find anything.
Csaari77 is offline
Old 03-25-2009 | 12:16 PM
  #20343
i use this guy
he is a bit expensave compared to rcmart of rc market but hos stuff usually comes in 3 days
http://www.vellrip.com/store/home.asp
found them i stock , this is what i ordered for mine at christmas
http://www.vellrip.com/store/product...asp?p=337&c=78
http://www.vellrip.com/store/product...asp?p=742&c=78
http://www.vellrip.com/store/product...asp?p=744&c=78
sidecarphil1 is offline
Old 03-25-2009 | 03:12 PM
  #20344
JayL's Avatar
back been bothering me but I am trying/wanting to race real bad! I miss all my non nitro buddies
JayL is offline
Old 03-25-2009 | 03:26 PM
  #20345
STLNLST's Avatar
Just find you a turn marshall and you're set
STLNLST is offline
Old 03-26-2009 | 03:41 AM
  #20346
penmark67's Avatar
Default yep
Yeah thats right , fine tune for your track though 26mm for a tight track
and 25mm for sweeping longer track
3 hole pistons and 50wt front 3 hole and 35wt rear
try white fronts and blue rears and tyre tweak rears only
also keep your ride height neutral say 5mm front rear.
H T helps
penmark67 is offline
Old 03-26-2009 | 07:13 AM
  #20347
Kwikvdub's Avatar
Anybody know or have a link to a website where I can get a LiPo weighted plate.
Thanks!
Kwikvdub is offline
Old 03-26-2009 | 07:24 AM
  #20348
Trips's Avatar
Thanks!
Stormer has THESE but they're a little pricey...
Trips is offline
Old 03-26-2009 | 07:30 AM
  #20349
Arrow 415 MRE - UK
A bit of a cheek, I have a 415 MRE(ceramic+ Sq) forsale ... but based in UK £100 + shipping good condition Also spares(for extra).. pm me for pixs etc
Andyg01 is offline
Old 03-26-2009 | 07:41 AM
  #20350
94eg!'s Avatar
That price is crazy high. Nexus racing sells the same thing for $27...
http://www.nexusracing.com/product_i...oducts_id=2584
If I was gonna spend $50 on a tray for my 415, I would rather buy something nice like this that moves the lipo out from under the bulkhead:
http://www.bittydesign.net/PortaLipoTAMIYA-TRF-ING.htm
94eg! is offline
Old 03-26-2009 | 07:46 AM
  #20351
Kwikvdub's Avatar
Thanks Guys!......Awesome stuff!
Kwikvdub is offline
Old 03-26-2009 | 10:58 PM
  #20352
bigkoitat's Avatar
I thought I share with you guy's what I made
I could'nt find any diff covers for my cars, everybody was out of stock. So I decided to make my own using the lexan leftover from cutting out the wheel opennings on the bodies. Withe the 416 half the diff balls are exposed so I needed to do somthing. From the Pics I used clear on the 416, it now serves as an inspection window too. On the 415 I used white. You basically just use the pulley as a template and cut with lexan scissors, next I used the body reamer for the center hole. And bam your DIY diff covers
415
416
and the body I used when I cut the wheel openings
since I built the cars I have never rebuilt the diffs even after 6 races and practicing everyday on some light dust asphalt
bigkoitat is offline
Old 03-27-2009 | 07:36 AM
  #20353
i like the dust covers
but i want you to paint me a body shell
did you use masks or stickers ??
or was it airbrushed ??
Old 03-27-2009 | 09:26 AM
  #20354
JayL's Avatar
nice cover idea,
I just use old stickers and cut them out like a donut and they 'stick' to the diff gear, I put some anti wear grease where it touches the outdrive and nothing get's through
JayL is offline
Old 03-27-2009 | 10:05 AM
  #20355
bigkoitat's Avatar
i didn't paint the bodie, Franksbodies painted it for me. He airbrushed it too.
