Old 02-17-2006, 11:22 PM   #12841
R/C Tech Charter Subscriber
Originally Posted by JRRobiso
Something new to try out. I believe they are from the TA05.
It will change the internal ratio to 2.25 since the white pulleys are 36t instead of 35t.
NismoSkyline17 is offline   Reply With Quote
Old 02-18-2006, 08:10 AM   #12842
JRRobiso's Avatar
Send a message via Yahoo to JRRobiso
Are there any benefits to that besides the ability to use a larger pinion gear when running mod motors (still using the stock spurgear)?
TAOB Racing Team (2004) | Team Driver #101
TRF415MSX | TRF415MRE | TRF801X/XT | K V1 RRR Evo WCE | K IGT2 Audi A4 DTM | AE SC10 4X4
AKA | Airtronics M11 | Spektrum Pro | Speed Passion BL | OS Engines | Sidewinder Fuel | Ko Propo/JR HV/Savox Servos | MuchMore Racing | Xenon Racing | Speedmind | Sorex Tires | Twister Tires
JRRobiso is offline   Reply With Quote
Old 02-18-2006, 08:11 AM   #12843
TryHard's Avatar
Originally Posted by King of B Main
tryhard, I sent you a pm, need help
back at ya
| THard.co.uk | Xray | MuchMore |
Old 02-18-2006, 08:53 AM   #12844
Trader Rating: 35 (97%+)
Send a message via AIM to King of B Main
thanks bro will try some stuff today and thanks for your website alot of help
King of B Main is offline   Reply With Quote
Old 02-18-2006, 09:09 AM   #12845
You would think it would help with acceleration. Think of it as going from a 3.88 to a 4.10 in a Camaro. Makes it more of a stumb puller. But I'm not sure if that really is the case, e.i. X-ray went down in ratio to a 1.77 from a 2.XX. I would think it would have more to do with using a different size spur/pinion to move the motor fore/aft. I don't know how much the 415 is affected by motor placement but I do know it makes a big difference on a car like the RDX.
Brian Anthony is offline   Reply With Quote
Old 02-18-2006, 10:52 AM   #12846
What I think would be interesting to try is use a white pulley either front or rear to change the handling characteristics. Back when you could get the XXXS in regular kit form they gave you 38t pulley as well as the stock 39t pulleys and the instructions explained about overdriving and underdriving.
Old 02-18-2006, 11:43 AM   #12847
tamiyarcracer's Avatar
Send a message via Yahoo to tamiyarcracer
I tried the 415 pulley on my TA05 and the center hole is a much different size.
tamiyarcracer is offline   Reply With Quote
Old 02-18-2006, 11:45 AM   #12848
They (Losi) really only used it in stock and 19t as overdrive adds steering. I don't believe they used it in mod.
Old 02-19-2006, 08:40 AM   #12849
JRRobiso's Avatar
So with that said, the 415 pulley does not fit TA05 due to the center hole is smaller but the TA05 pulley will fit the 415 diff unit?
I noticed that to myself coz I bought the TA05 spool (intended for my 414M but pulley ctr hole was too small to fit the spool unit). I ended up using the steel outdrives that came w/ TA05 spool & used it instead w/ the TAM 415 spool since the delrin outdrives don't last long which I also noticed some of the TRF drivers @ the TITC '06 race have done as well.
Old 02-19-2006, 09:06 AM   #12850
JRRobiso's Avatar
Exclamation
Mark R. & TRF415 MSX wins open mod title in TITC 2006 race.
http://www.titc.in.th/index.html
Old 02-19-2006, 09:09 AM   #12851
IB dominate titc 2006!!!
Tamiya
Much More Racing
LRP electronic
Futaba
Speedtechrc
trf racer is offline   Reply With Quote
Old 02-19-2006, 12:02 PM   #12852
Sushi Man's Avatar
Send a message via AIM to Sushi Man
Hey do u guys know the size of the diff bearings for the tamiya cars?" is it 5 x 8mm ??
Sushi Man is offline   Reply With Quote
Old 02-19-2006, 01:31 PM   #12853
The ones in the center of the diff are usualy 8mm x 5mm
Old 02-19-2006, 03:20 PM   #12854
Burlap's Avatar
Send a message via MSN to Burlap
That'll shut up the Cyclone and XRay racers for a while.
Burlap is offline   Reply With Quote
Old 02-19-2006, 03:35 PM   #12855
Ya, that's right. GO TAMIYA!!!
trf_racer is offline   Reply With Quote
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
