Tekin RS ESC sensored >
Old 02-28-2009, 05:38 PM
  #2656
Gone Racin's Avatar
Default RS esc
Hello, My son runs outdoors rubber tire TC open mod. 4.5LRP X12 big open track, can someone help with good setup for this RS Pro speed control for this motor. Stock settings no HOTWIRE yet. Any HELP. Thanks Ron H,
Gone Racin is offline
Old 02-28-2009, 05:55 PM
  #2657
Trader Rating: 68 (100%+)
thanks for thhe quick reply.. mission accomplished...gotta love this tekin stuff
todb is offline
Old 02-28-2009, 07:05 PM
  #2658
xtrememadness's Avatar
Originally Posted by Randy_Pike
Sure,
Try running the 7.5 in dual mode, Timing advance at 50, Nuetral width at 10, TP 3. Motor timing set at default(12).
thanx randy
xtrememadness is offline
Old 02-28-2009, 10:39 PM
  #2659
syndr0me's Avatar
Trader Rating: 32 (100%+)
The RS works great with zero physical timing and 100% boost. I bought a second one for my TAwesome05 project.
syndr0me is offline
Old 03-01-2009, 01:25 AM
  #2660
Default RS Pro ESC
I like the RS ESC so much that I bought the 3rd RS ESC 2 weeks ago. It went really well in my 1/10 pan car but this morning, the light appeared dim and there is no sound once I switched on the ESC.
The steering works but I cannot move my BL motor. Has anyone else experience this problem?
azmio is offline
Old 03-01-2009, 03:14 AM
  #2661
miller tyme's Avatar
Sounds like low main battery voltage, priority to the Rx nothing to the motor.
miller tyme is offline
Old 03-01-2009, 03:23 AM
  #2662
sg1
sg1's Avatar
Trader Rating: 79 (100%+)
Agree, I had a binding problem once that did the same thing. I rebound the radio and it was fine then.
sg1 is offline
Old 03-01-2009, 05:02 AM
  #2663
Currently the only version that is available to the public from me is 2.9/ 189
The team is using another version that has some 4 cell improvements.
Once we're satisified that it's as solid as 189 we will let you ALL know and post it on the site.
Good news for the 12th drivers.
Ahmed Aman is offline
Old 03-01-2009, 06:40 AM
  #2664
the light is still dim even when fully charged battery is connected to it. Even the hotwire connection wont be able to light up the ESC
azmio is offline
Old 03-01-2009, 07:51 AM
  #2665
Geezatec's Avatar
Check batteries NiMh or lipos, lipo cut-off, BL or Brushed. ESC soldering & motor solder, may come loose. If soldering connection came loose, Temp problem. Type of motor may have change, Check motor type on onboard(ESC) or on hotwire.
Geezatec is offline
Old 03-01-2009, 08:32 AM
  #2666
Krio's Avatar
Trader Rating: 159 (99%+)
You need to downgrade and then upgrade the esc software, eg put 180 on and then back to 189. I see this happen on occasion and after refreshing the software you should be good to go.
Krio is offline
Old 03-01-2009, 01:34 PM
  #2667
okayplayer
Guest
Posts: n/a
Hi,
1/ When I go through the firmware and plug my Tekin RS PRO in the hotwire; after an update check it says that no update is available... but the version displayed is 180...
Is there a problem?
2/ I'm using a Tekin 6.5T on asphalt (rubber & foam) with my 1/10 only sensored mode... any recommended settings to start with ?
Cédric
Old 03-01-2009, 01:46 PM
  #2668
SpraydbySprague's Avatar
Location: Conducting aggressive board meetings at my local track
Trader Rating: 64 (100%+)
Originally Posted by okayplayer
Hi,
Is there a problem?
Cédric
I'm guessing you have Windows Vista and tried to re install the 1.89 version into your computer after uninstalling the old version on your computer. If so check this out.
http://www.rctech.net/forum/electric...ml#post5231294
Read post #1867. This should help.
SpraydbySprague is offline
Old 03-01-2009, 01:50 PM
  #2669
okayplayer
Guest
Posts: n/a
Thanks for the reply but... I'm running Windows XP
I uninstalled Tekin Hotwire, then downloaded the "latest" from here :
http://teamtekin.com/hotwire.html
After launching the program, I click Yes to check for updates... it says no updates found for your ESC.
After that I go to the tekin hotwire program and current version is displayed : 180.
2/ Any ideas on the 6.5T recommended settings?
Cédric
Old 03-01-2009, 02:10 PM
  #2670
You can't download the 189 update yet but if you send me you e-mail in a pm i will send it to you.
mikky32 is offline
