Team Magic E4 Thread
#1189
Well testing today went very well , kit set up was really good. Wolf's choice of chassis and top deck was spot on!!! The C1 edition is great!!! I made a few changes from the kit set up to suit the track minor changes went to a stiffer spring in the front (AE Blue) and (AE Green) in the rear. Im testing on a medium track tomorow . The car was very stable and very smooth, very quick changing direction. I will post both set ups tomorow nigh, one of them is for a large 1/8th scale track the other one will be for a smaller technical track.
#1190
Two green springs #3941 12.0 lbs/in
Two silver springs #3942 14.4 lbs/in
Two blue springs #3943 17.0 lbs/in
Two gold springs #3944 19.5 lbs/in
Two red springs #3945 22.0 lbs/in
Two copper springs #3946 25.0 lbs/in
Two purple springs #3952 30.0 lbs/in
Two yellow springs #3953 35.0 lbs/in
Two white springs #3954 40.0 lbs/in
One color/rate sheet with part number
Are these springs any good for the E4?
#1191
#1192
after testing friday,saturday and racing today i think that i have a very good set up for both small-medium tracks and it works very well on a big 1/8th scale nitro track. Ill have it posted in a little bit as soon as i put it on a set up sheet.
#1193
Hey marco can't wait to see the set up. just curious, is the set up for mod or for 10.5 or 13.5(stock). Good had a bit of problems today. that okay, all part of learning a new car,
Taking a week off then it's back to the grind with this car.
#1194
Over all the set up worked very well with both motors at both tracks.
#1196
Many Thanks for the setup sheet.
I see you use the single arm steering system, Is this better than the 2 arm, if so why? Will it give me more steering?
I see that Wolf do a kit "503901 E4 Single Arm Steering Kit" their is no picture, so I cant tell if everything I need is included, does anyone know?
Will give your setup a try and let you know.
All the best Anthony in wet London.
#1197
#1198
WOW
Thanks for a quick response.
Just studing the sheet further and you set "Down Stop as 2mm over RH". Can you please explain this a little more and tell me where you make these measurement from.
Thanks and sorry for so many questions, their just is not that many people running this car in the UK so setups/help are a little hard to come by. I am sure I must be able to get it to corner and change direction faster. Apart from that the car is nice and stable and predictable.
I stick with the 2 arm one if it doesnt make any real difference.
Thanks Again Anthony
#1199
WOW
I hope i didnt confused you (since I confused my self writting it
)I ran the double steering rack before on my Original E4 and it felt the same so like i said its just a personal prefrence.
#1200
I've run both the single and dual steering link, and the dual will make the car react off center quicker. Allegedly, when you have shorter steering links, you get quicker reaction off center, and that's what the duo link has over the mono link...the mono link system makes the steering smoother and more consistant, and better on bigger open tracks.
Regards,
Yohan
