Team Magic E4 Thread >
Old 08-15-2008 | 01:14 PM
  #1186
Marcos.J's Avatar
Super Moderator
Originally Posted by yyhayyim
the SS copy cat track? Cool...hurry up and get typing!!!
Marcos.J is offline
Old 08-15-2008 | 03:31 PM
  #1187
STLNLST's Avatar
Most of the fast guys have a paint scheme...........
STLNLST is offline
Old 08-15-2008 | 08:02 PM
  #1188
Marcos.J's Avatar
Super Moderator
yes one color scheme
Marcos.J is offline
Old 08-15-2008 | 08:06 PM
  #1189
Marcos.J's Avatar
Super Moderator
Well testing today went very well , kit set up was really good. Wolf's choice of chassis and top deck was spot on!!! The C1 edition is great!!! I made a few changes from the kit set up to suit the track minor changes went to a stiffer spring in the front (AE Blue) and (AE Green) in the rear. Im testing on a medium track tomorow . The car was very stable and very smooth, very quick changing direction. I will post both set ups tomorow nigh, one of them is for a large 1/8th scale track the other one will be for a smaller technical track.
Marcos.J is offline
Old 08-15-2008 | 08:35 PM
  #1190
Two green springs #3941 12.0 lbs/in
Two silver springs #3942 14.4 lbs/in
Two blue springs #3943 17.0 lbs/in
Two gold springs #3944 19.5 lbs/in
Two red springs #3945 22.0 lbs/in
Two copper springs #3946 25.0 lbs/in
Two purple springs #3952 30.0 lbs/in
Two yellow springs #3953 35.0 lbs/in
Two white springs #3954 40.0 lbs/in
One color/rate sheet with part number
Are these springs any good for the E4?
Smarty is offline
Old 08-15-2008 | 10:07 PM
  #1191
Marcos.J's Avatar
Super Moderator
yes but you need to use the bottom collars for the TC5 part # ASC6475 so you can get the lower ride height that you need. You can use the Tamiya short springs too they are a perfect fit.
Marcos.J is offline
Old 08-17-2008 | 02:25 PM
  #1192
Marcos.J's Avatar
Super Moderator
after testing friday,saturday and racing today i think that i have a very good set up for both small-medium tracks and it works very well on a big 1/8th scale nitro track. Ill have it posted in a little bit as soon as i put it on a set up sheet.
Marcos.J is offline
Old 08-17-2008 | 04:48 PM
  #1193
Hey marco can't wait to see the set up. just curious, is the set up for mod or for 10.5 or 13.5(stock). Good had a bit of problems today. that okay, all part of learning a new car,
Taking a week off then it's back to the grind with this car.
cyrrus is offline
Old 08-17-2008 | 04:54 PM
  #1194
Marcos.J's Avatar
Super Moderator
After we race we went to our local track ( Adrenaline RC) to practice some more, its a medium track, and I ran the same setup with a 13.5 and it was really good. My fastes lap there was 11.28 with a 13.5 and another racer's fastes lap was a 11.00 with a Hacker 10.5motor.
Over all the set up worked very well with both motors at both tracks.
Marcos.J is offline
Old 08-17-2008 | 04:59 PM
  #1195
Marcos.J's Avatar
Super Moderator
Here is the set up.
Marcos.J is offline
Old 08-18-2008 | 05:34 AM
  #1196
Many Thanks for the setup sheet.
I see you use the single arm steering system, Is this better than the 2 arm, if so why? Will it give me more steering?
I see that Wolf do a kit "503901 E4 Single Arm Steering Kit" their is no picture, so I cant tell if everything I need is included, does anyone know?
Will give your setup a try and let you know.
All the best Anthony in wet London.
A Coldman is offline
Old 08-18-2008 | 05:39 AM
  #1197
Marcos.J's Avatar
Super Moderator
I like the single arm steering, just my prefrence didnt noticed that much diffrence between the two. My kit (the C-1 ) only came with the single steering kit, Im not sure if the kit that you are asking does but I can find out from Wolf for you.
Marcos.J is offline
Old 08-18-2008 | 05:45 AM
  #1198
WOW
Thanks for a quick response.
Just studing the sheet further and you set "Down Stop as 2mm over RH". Can you please explain this a little more and tell me where you make these measurement from.
Thanks and sorry for so many questions, their just is not that many people running this car in the UK so setups/help are a little hard to come by. I am sure I must be able to get it to corner and change direction faster. Apart from that the car is nice and stable and predictable.
I stick with the 2 arm one if it doesnt make any real difference.
Thanks Again Anthony
Old 08-18-2008 | 06:46 AM
  #1199
Marcos.J's Avatar
Super Moderator
WOW
for the downstops i 1st make sure that they are even on both sides with a droop gauge, then I put the tires on and set the ride height that i want , then i liftup the car until the tires start to leave the ground and then i slide the ride height gauge under it,i then adjust the droop screws until I reach the mm over the ride height that I want. I just add the mm over ride height to the ride height thats on the car.
I hope i didnt confused you (since I confused my self writting it )
I ran the double steering rack before on my Original E4 and it felt the same so like i said its just a personal prefrence.
Marcos.J is offline
Old 08-18-2008 | 07:48 AM
  #1200
yyhayyim's Avatar
Hi Anthony,
I've run both the single and dual steering link, and the dual will make the car react off center quicker. Allegedly, when you have shorter steering links, you get quicker reaction off center, and that's what the duo link has over the mono link...the mono link system makes the steering smoother and more consistant, and better on bigger open tracks.
Regards,
Yohan
yyhayyim is offline
