Go-Tech Engines Thread
#3586
No-one said GO are the best...but
-will last long if they would tune right yes
-perform great as long as you get the right one for your application should but yest the carbs suck so they dont run right
-and they do try to fix there problems with the carbs
Others throw it at the tunner/driver if something goes wrong with there engine...see "high end engine" own forums!! blame the tuner for not knowing how to tune a engine ass backwords
In off road a lot of things can go wrong...
-your air filter might go off
-a runaway
I don't even want to imagine this with a >$300 engine.
Do you want to discuss parts availability and cost...i don't think so.
RB/Novarossi rods are $50-$60
Picco-i saw somewhere they charged $78 for a rod.
-a runaway
#3587
I am currently running a .21 3pr in my truggy conversion, i know that the first problem is that I am running a conversion. All joking aside I am considering going to a .25 6p oppossed to the .21 5p because my truggy is so damn heavy. Any advice would be greatly appreciated.
Thanks.
Thanks.
#3588
Higgs2ca i run the GO .25 6 port engine in my jammin crt x1 now transfered into the x2 that just arrived and i love it i run it with the go 2047 pipe and it tears up the track nicely. most of all it gets pretty good fuel milage for a big motor i think im getting around 7 1/2 to 8 mins. i cant wait to try it in the jammin x2 this weekend. thnx Will G
#3589
sorry my picco runs great no carb issues but its sad that every one brings up issues with companys that make 3 times the engines go does yet go's percentage on problems is higher then theres. every company makes a couple bad engines but why is it that go seems to continue to sell the bad engines with bad carbs
At least not so popular.
And i don't think that Picco sells more engines than GO does.
And they did/or do have carb issues...do a search.
And also...try to find a rod for a P7R engine...please do, because my friend needs one and not the $78 i referred to.
He has been looking for one for 4 months now.
Even nitrohouse is out of stock.
#3590
That's because there is a thread for GO engines and not for Picco.
#3591
Yeah you could get a V-spec and have it lose compression in the first gallon and be a nice heavy paperweight also just like 4 other locals had done to them here and many others I have read about. Might be a hit or miss thing with that OS problem but not a $300 chance I want to take.
#3592
I didn't say my friends picco had issues...i said he is looking for a rod...to replace the OLD one.
And relax...if you don't like them don't buy them.
If you do want to give them another shot that's your call.
#3593
I have 4 piccos not one of them has a carb issue and they all hold tunes and run like raped apes.
have seen several locals try these go techs and they all have ended up selling them or just out right throwing them away
#3594
Everybody has bad experiences dude, I had 1 or 2 myself but your dwelling toooo much on it bro just chill out. If I wasted my time bitching about everything I didnt like I wouldnt have any time. I just bought my 1st GO mill a PTM 5 port and if I have carb issues oh well just fix it. I am just saying where is the fun in the hobby if your just going to be all negative about everything.
#3595
I am not real sure where everyone gets that you have to replace bearings in V-specs but I have had 4 of them and I have put 25 gallons in 3 of them so that is 9 gallons on two of them and 7 in the last one and then I got a lemon on this last one and it lasted about 3/4 of a gallon but I have yet to do anything to those other three
#3596
and as far as go techs go I can't say anything bad yet lol I have 1/2-3/4 of a gallon through it and love it and my buddy has one with over a gallon on it and it will run 8-9 min on a tank and will run right with those 500.00 speed tuned v-specs
#3597
#3599
http://www.amainhobbies.com/product_...oducts_id/4776
http://www.amainhobbies.com/product_...oducts_id/8844
(I think the first two are the same except for the venturi carb restictors)
http://cgi.ebay.com.sg/Novarossi-3-5...QQcmdZViewItem
I also found three different OS carbs.
http://www.amainhobbies.com/product_...ducts_id/11865
http://www.amainhobbies.com/product_...oducts_id/6213
http://www.amainhobbies.com/product_...ducts_id/14754
Which would any of you guys recommend?
#3600
Which Novarossi carbs are you or others using? I found three different Novarossi carbs.
2Likes
