Go-Tech Engines Thread
#3617
#3618
Thanks to everyone that posted and pm'd me with help on getting my motor started (piston was getting stuck). I finally got it started and idled through the first tank last night. However, then, and now the motor will not stay running without the Glow ignitor attached. I've got the HSN about flush and the LSN is about 1.5 turns in from flush (info from page 78). I'm using OS P3 plugs, have the head wrapped, and have to keep hitting the motor with the heat gun to keep the temps up in the 240 - 250 range. Any ideas as to why the engine dies without the ignitor on?
Oh yea, I'm using Odonnells 30%.
#3619
Hey smracer31, how many shims are you running under
the head button? I have always ran one thick copper
and one thin copper head shim on all four of my GO motors,
from the first time that they were fired up. I run them from
the begining on 30% nitro and have never had a glow plug
blow. Keep the HSN a little fat and they never stop pulling.
#3620
#3623
Mabey the new plug was bad? If you didn't live three thousand
miles from me, I'd say bring it over and we would get it broke in.
I just bought a bunch of P3's, P6'S and O'Donnell 77T's from a
friend for cheap. I would like to help find out what is giong
with your motor. Can anyone in SoCal offer to help?
#3624
#3625
Well I was having a running problem last weekend that I posted earlier and was reading some posts and made sure my needle settings were flush on the HSN and 2.5 turns in from flush on the LSN for my 7-port and TA-DA!!!! RAN BEAUTIFUL THE WHOLE TIME!!! Was running between 245-260. I only barely tuned it with the LSN and turn it in a half turn more because it would load up a little at idle and it was perfect! Idled forever and tons of power. Thanks for the info guys! NO CARB PROBLEMS HERE.
I don't think the needle thing is really that much of an issue. Itīs more that these Go engines tune different from most other engines, and if thatīs the case, so be it. As long as the engine runs hard when you have the tune correct, you canīt ask for more than that.
The needles are very sensitive, especially the LSN, but once you get it right - bingo !! A lot of the guys running Goīs down here have the long LSN needles and we donīt seem to have too many problems. We have several really good tuners in our group that have the tuning sorted and the rest of us feed off their input.
I have just changed to a fuel with 5% less oil content than what I was previously running and found I needed to lean both needles just a little. LSN is now in just a hair over 2 3/4 and I leaned the HSN about 2 hours.
You have to allow a bit of leaway on those base settings to allow for fuel, pipe etc, but if you use the flush HSN / 2.5 in LSN as a starting point you are never far off it would seem.
#3627
Nice one vnmsgt. Those settings seem to solve most problems !!
#3628
The needles being wrong is what causes these engines to tune different. The "good tune" window is very small....and usually is found by using the lsn the most which is completely backwards from all other engines. Also...out of the box the needle settings are not far from race tune. People instinctivley reach to the hsn to lean out some during break in....it's almost perfect out of the box. These engines tune almost totally from the lsn.....sometimes even when you have high engine temps (280+ deg. F.) leaning the lsn will make it better if your hsn is set properly....usually around flush.
I also strongly recommend that everyone seal the slide boot to the carb....it can suck dirt in here. It will pull dirt while your WOT...then push it into the carb when off throttle. When the dirt builds up.......it falls into the engine equalling a bad day and a toasted engine.
My '08 PTM 3R is running great with no tuning problems....I will gladly help anyone with their tuning problems if I can.
Shane Keller
205-281-3089
#3629
Shane Keller
205-281-3089
Shane Keller
205-281-3089
as for the engine shutting off after removal of the GP, i get this sometimes when breaking in engines, the OS plug can sometimes be bad right out of the box, just the way it is, but also as stated before the hsn is set almost perfect, i now fatten it up befor breakin about 1 full turn, the lsn is set fat, this is what can cause the engine shutting off when you pull the GP. lean it on bottom some and it will idle when you pull it off, bump the idle up a bit and your good, i like to see little spirts of fuel popping out of the carb during breakin idle, this is telling me it's plenty fat on bottom and is well lubed, as you turn the lsn you will notice this go away, so leave it for the whole breakin. and with the HSN set a full turn out from flush it will allow you to tune in a more common way, but only lean till you reach flush or a smidge below, and then hit the lsn
#3630
Iv done it the way brain has suggested ..and it works...I kinda had a hard time getting the lsn to turn smooth...so i removed it and installed a new oring..use a very light amount of grease(dont go carzy here),,and the lsn was so very easy to turn to find the sweet spot...
My friend has a 7port and gave up got a nova carb...
Once you has it set.leave it..and your done..
thanks brain
thanks brain
2Likes
