Go-Tech Engines Thread
#4336
I think it is cheaper to rebuild these engine. A new piston and sleeve is not as expensive as Novarossi or OS. I think 22racer can rebuild your engine. He is also an authorized Go Tech deler. If you need a new mill or want him to rebuild your current one contact him.
#4337
A 7 port has more top end than the 3 or 5 ports, the 7 port has 3 exhaust ports which is what give it more top end. As a general rule of thumb more ports means more top end but not always the case. The 5 port has the most bottom end of the Go motors.Do tou have the 3 port sport? If so I have experimented with some mods on the sport and I like it better than the 3 port race spec with the mods.
The turbo plug is just a better design and seals at the combustion chamber instead of at the washer, you could probably feel the difference between the two plug styles but not a big overall difference. The 5 and 7 ports probably will tune a little harder than a sport motor but they tune pretty easily.
Rex
Rex
#4338
Thanks Tree, yes I do rebuild motors, I charge $30.00 to go through a motor, this includes, pinching the sleeve to regain compression if needed, replacing bearings if they need it or upgrading to ceramic, cleaning and inspecting the motor, especially the crank and rod wear. If the motor is not worth rebuilding I would not charge you anything. All parts needed would be extra, a Go rod is only $18.69.
I do not just rebuild Go's I will work on anything, .12-up to .32's.
I also mod motors, I've been experimenting for quite a while now and have looked at several other modded motors and am confident enough to do it for customers. I only charge $40.00 for a mod or $20.00 with a rebuild.
Rex
#4340
I just got a new 5 port and have a couple of questions:
1) Any tricks to get it to turn over? My Losi box will not turn it over even after getting it to 240 with the heat gun. I don't really want to have to move pins around on my truggy box to see if that will work, so any advice would be greatly appreciated. Does an engine really need that much pinch?
2) The carb has a small "wiggle" to it even when the pinch bolt is tight. When I got the engine the carb was really tight into the case. I took the pinch bolt all the way out and still had to heat the case just to get the carb to break loose and come out so I could seal everything up. Will this play affect the way the engine runs?
I don't know, I really want to like the GO engines, a lot of people here seem to have good success with them, but, it seems the carb issues are still around even with the latest generation. I have a 3 port race as well, that sits on the shelf at home because I just cant get it tuned, serious carb probs. I don't have any tuning issues at all with any of my other engines (V-spec, Falcon, Nova's) I really don't want to buy a new carb for it because at that point I should have just went ahead and bought the OS, RB, Nova...
Any advice would be much appreciated. I know they can be good mills, I've had brief glimpses of what they could do when the 3 port was actully working and was quite pleased, but, chasing a tune all day long can take some of the fun out of going to the track.
Thanks!
Thanks!
#4342
Hi everybody, I have a litle problem with my go 7port .21 engine.
I run it in a Mugen MBX5R. Uses os P3 plugs no turbo top
When I kome to the track and starts it run a tank fine, but after it stops and I refuel it's werry dificult to start. Anybody that has had this problem??
#4343
#4345
Thanks!
Thanks!
#4346
#4347
Thanks!
Thanks!
#4348
Make sure you have the run in shim fitted (makes things a lot easier).
Loosen the glow plug slightly to ease the compression, this will make starting a lot easier too.
The Go's are super tight, but if you heat it up and loosen the plug you should not have that much trouble
For those guys having trouble tuning the newer Go's (long LSN models), go to page 131 on this thread and read the posts by Massive Mods and Retro RC. There is nothing wrong with the carbs or motors, it's just a tuning thing. The long LSN makes these motors tune slightly different to a lot of other main stream motors. Set the HSN and tune with the LSN as suggested in these posts and you will be sweet.
#4349
Thanks for the input - it's greatly appreciated.
I do have the break-in shim fitted. I had fully charged stick packs and a fully charged glow igniter as well. I guess just more patience is all it's going to take!
If I can't get it to roll over tonight on the losi box I'll switch over to the ofna one and give that a try.
Any advice on the carb "wiggle" ? It's very small, like .5mm either direction, but definitely noticible. If it's not going to affect performance at all I'm not going to worry about it. I did a quick leak test and everything was ok there, so, probably no big deal.
Thanks again,
Dave
Thanks again,
Dave
#4350
2Likes
