Go-Tech Engines Thread
#1817
OK. Does the 5 port .21 Turbo come with a plug? What plug does it come with? What other plugs fit....do Nova Rossi plugs fit?
It's still prety chilly here at the moment. Is a 6 good for now?
Thanks for the help.
British Menace
British Menace
#1820
British Menace
#1821
I wouldn't recommend breaking in a Go with a #6, I tried a couple weeks ago and it wouldn't idle unless I leaned it out. With an Odonnel 97t it idled like a champ! I even tried a Nova #5 and I still couldn't run it nearly as rich as with the 97t. Imo wait and get a 97t for break in, the #6 will be fine for racing.
Rex
Rex
#1822
Rex
Rex
British Menace
#1825
Derrick the clutch would probably be your best bet, .9 springs or carbon shoes. Another thing to try also would be to put a standard head button on the engine if your not running one already. The standard head 7port will be a little more forgiving on bottom. Also you want to get the engine to run up above 210, otherwise you are gonna do some damage to the engine.
#1828
any turbo plug will work, the OS short plugs are recommended for the standard head GO, using the long standard plug will allow the plug to protrude into the cylender to far, some people use a long plug but use 2 washers to raise it some, save yourself the hassle and use a OS short plug, as for using a med or cold plud for breakin, they work fine, the plug that comes with a standard head GO is a med and they breakin fine, i just broke in a race 3 port with a OS p6 for a friend, the lhs didn't have any P3s, raced it on the same plug, just bump the idle up, and install the extra shim.
#1829
Hey guys, I just wanted to inform everyone that we will changing a few things as far as what we offer, untill further notice we will only be modding engines that are sent in to be done. This is nothing to be alarmed about, we are only going through a restructur on things. In doing this we are looking at offering better customer service and faster turnaround times for our customers. We have built a reputation on great service and customer support, and we want to make it even better. We ARE NOT CLOSING, just changing opperation precedures. The website is closed down for this reason, and will be relaunched in the near future. If i can answer any questions regarding this matter, please feel free to give me a shout.
Brian Carey
Brian Carey
2Likes
