Like Tree2Likes
Go-Tech Engines Thread
Old 03-01-2008 | 12:00 AM
  #1816
Satoch check PM
LosiMadMan is offline
Old 03-01-2008 | 08:54 AM
  #1817
British Menace's Avatar
OK. Does the 5 port .21 Turbo come with a plug? What plug does it come with? What other plugs fit....do Nova Rossi plugs fit?
It's still prety chilly here at the moment. Is a 6 good for now?
Thanks for the help.
British Menace
British Menace is offline
Old 03-01-2008 | 10:01 AM
  #1818
Vigilante212's Avatar
The turbos dont come with plugs because Go doesnt make a turbo plug yet. Any turbo plug should work. Recommend the o.s. p3
Vigilante212 is offline
Old 03-01-2008 | 01:51 PM
  #1819
GenReaper's Avatar
NR C6TF works the best IMO.
GenReaper is offline
Old 03-01-2008 | 03:30 PM
  #1820
Hey thanks for the reply's. I think I have some NR 6's. I'll try them.
British Menace
Old 03-01-2008 | 04:04 PM
  #1821
22Racer's Avatar
I wouldn't recommend breaking in a Go with a #6, I tried a couple weeks ago and it wouldn't idle unless I leaned it out. With an Odonnel 97t it idled like a champ! I even tried a Nova #5 and I still couldn't run it nearly as rich as with the 97t. Imo wait and get a 97t for break in, the #6 will be fine for racing.
Rex
22Racer is offline
Old 03-01-2008 | 04:08 PM
  #1822
Rex
Ok thanks Rex.....sounds like a plan. Odonnel 97t it is.
British Menace
Old 03-01-2008 | 04:40 PM
  #1823
BlueisBetter's Avatar
go pipe..............!!!!!!!!!!!!!
any info lads
BlueisBetter is offline
Old 03-01-2008 | 05:52 PM
  #1824
I have one its nice looks kinda like a jp-4 runs great with my 5 port good power all the way around.
JustinD is offline
Old 03-01-2008 | 09:37 PM
  #1825
Rocket42's Avatar
Derrick the clutch would probably be your best bet, .9 springs or carbon shoes. Another thing to try also would be to put a standard head button on the engine if your not running one already. The standard head 7port will be a little more forgiving on bottom. Also you want to get the engine to run up above 210, otherwise you are gonna do some damage to the engine.
Rocket42 is offline
Old 03-02-2008 | 10:41 AM
  #1826
You lot using the short body or long body Tourbo NR 6's?
tjpMT2 is offline
Old 03-02-2008 | 10:49 AM
  #1827
You have to use short plugs are you will mess up the engine it uses short plugs like the OS so thats why people recommend the OS p3's which is what I run as a Team Driver is the best thing so far.
JustinD is offline
Old 03-02-2008 | 12:33 PM
  #1828
mugenb46's Avatar
any turbo plug will work, the OS short plugs are recommended for the standard head GO, using the long standard plug will allow the plug to protrude into the cylender to far, some people use a long plug but use 2 washers to raise it some, save yourself the hassle and use a OS short plug, as for using a med or cold plud for breakin, they work fine, the plug that comes with a standard head GO is a med and they breakin fine, i just broke in a race 3 port with a OS p6 for a friend, the lhs didn't have any P3s, raced it on the same plug, just bump the idle up, and install the extra shim.
mugenb46 is offline
Old 03-02-2008 | 12:35 PM
  #1829
mugenb46's Avatar
Hey guys, I just wanted to inform everyone that we will changing a few things as far as what we offer, untill further notice we will only be modding engines that are sent in to be done. This is nothing to be alarmed about, we are only going through a restructur on things. In doing this we are looking at offering better customer service and faster turnaround times for our customers. We have built a reputation on great service and customer support, and we want to make it even better. We ARE NOT CLOSING, just changing opperation precedures. The website is closed down for this reason, and will be relaunched in the near future. If i can answer any questions regarding this matter, please feel free to give me a shout.
Brian Carey
mugenb46 is offline
Old 03-03-2008 | 05:40 PM
  #1830
Hey guys what do you have your immensity set on you temp guns with the 5 port? Also any tips for a freshly broken in 5 port? like what temps and stuff like that?
GRudinger is offline
