Novarossi engines thread
#2416
#2418
ive seen the ns12p run and i have run the ns21p boath are great engines not as good at the 353 12ct sct and +21 3c or 35+21 and 359. They make great strong power and good rpms perfect for club and every day use and pirfect for some smaller tracks. when you work it out the 353 359 367 novarossi engine packs are some of the best deals for your dollar. People start having probs from not replacing parts and trying to run the engines to lean. You will quickly distroy the new plus nova engines if you get to crazy with the tune. When you think the tune is right ritchen it 1 or 2hours and the engine will be a dream.
#2420
exhaust pipe .12 size
anyone knows what's the performance difference between the novarossi 51607 pipe (6mm stinger) and the nova efra 2630 pipe (5mm stinger) in terms of fuel efficiency and power (low or top end pipe) ?
also, does a 5 port .12 size engine means better suited to an exhaust(51607) with 6mm stinger and 3 port engine should use a exhaust(efra 2630) with 5mm stinger ? many thanks...
#2421
Trader Rating: 9 (91%+)
Has anyone heard the NOVAROSSI engine call "N21-2000" or something like that? It is 7port engine not sure for onroad or offroad.
#2422
JP has a tuned version on their website.
There is also a REX version called the R21-B2001
#2423
Would any know the diff. between nsr12s5 & ns12s5and also if tt12s51 is same as ns12s5.Thanks
#2424
#2425
Thanks Stefan. I'm looking for a crank for the Top motor I tried emailing nov.usa but no response & checked several websites like Ashford, Winners Circle but can't find the crank. I know it's an older motor so parts would be hard to find could you point me in a direction where one could be found. Any info would greatly be appreciated. Thanks
#2426
#2428
the N/T/R 21 2000 B is the off road and its 6 port and standard plug
the N/T/R 21 2000 R is a 7 port and i think its either an on road or Rally engine its Turbo plug.
I have a R212000BF they arent easy to find anymore. the 21 R 2000s are really rare and id like to pick one up.
I broke mine in about halfway and the front bearing took a crap and it crankwalked. so i just now put front and rear ceramics from TKO in it. Im going to finish breakin and strap it on an xdyno to see what it makes. I have a extremely modified original N21B 3 port and this thing stock is about the same performance.
The 2000 series is a mystery though, Novarossi acts as if they dont know anything about them.
#2429
I found a "cheap" way to fix your old engine:
http://www.modelbouwforum.nl/forums/...ad.php?t=50160
The Basic set does not differ a lot in timings compared with the old high end p/s set so with some grinding I hope I created a nice training/backup engine.
I have not started it yet.....
#2430
hi!i have a plus 21-5 and i must change the conrod.one shop near me has 2 conrods to choose from.the jp conrod {jp-07009}and the jp R6 light without the upper Bushing.Can i use any of these without promblems?and which is best?the light R6 last longer or not?
