Like Tree2Likes
Go-Tech Engines Thread
Old 11-23-2007 | 06:59 AM
  #541
Jason Halvorson's Avatar
Originally Posted by grizz1
Ran 5 port with shim fitted tonight. Big difference !! Behaves a lot more like a fully run in motor. Tunes easier and seems to run nice right through the rev range. Like salteen said, the difference is like night and day. I am much happier now
grizz1, glad to see it worked...i figured that was the problem...
Jason Halvorson is offline
Old 11-23-2007 | 10:41 AM
  #542
Paradoxmaker's Avatar
Originally Posted by Jason Halvorson
remember to remove the shim when the engine breaks in, you will know this cause the temps will go way down and then its time to remove the extra shim...
your engine is already shimmed for 30%, and the extra shim is ONLY for break in, and NOT for running 30%...repeat the engine IS shimmed for 30% out of the box!!!
So which shim are you guys calling the extra shim???
Mine only has 2 shims, 1 thin and 1 thick (i assume .1 and .2mm). It's been that way from day one running 25%-30% nitro with temps usually in the 190-230 range and i've got about 4 gal on it now..
I don't remember Russ ever saying to remove one after break in before But i think I remember someone saying before that shimming should be in the .6mm range...So more than anything i'm confused as hell now..
Paradoxmaker is offline
Old 11-23-2007 | 10:52 AM
  #543
salteen's Avatar
there are 2 installed when you get the motor. we're talking about the third shim that comes with the motor uninstalled which is to be used for break in and then removed after break in.
salteen is offline
Old 11-23-2007 | 11:01 AM
  #544
Rocket42's Avatar
Paradox your engine is shimmed correctly, after you ordered your engine the factory started including a extra .2mm shim. A lot of people where having problems with the break in due to the high metal pinch. If you add the extra shim during break in it makes break in much easier. After the engine is broken in the extra shim can be removed. You don't want to remove any shims until maybe after the 6 gallon mark the thin .1mm shim can be removed.
Paradoxmaker is old school he purchased one of the first 5 Go engines sold in the U.S., I have appreciated your support from day one, thanks.
Rocket42 is offline
Old 11-23-2007 | 12:24 PM
  #545
vr6's Avatar
vr6
well it's been since labor day that i have read this thread, i sold my eight to get into electric racing. i did not have much fun racing electric, so i'm getting back into nitro
i have a turbo 7port and loved every minute of it, i can not wait to get it running again. i need to get a pipe to get more low end, is 053 pipe still the pipe to have for this motor, or has someone else found a hotter pipe to put on
vr6 is offline
Old 11-23-2007 | 12:51 PM
  #546
grizz1's Avatar
My 5 port was from a new batch into New Zealand. This batch of motors are the first ones to be sold here with a country code and seriel number stamped on the side of the engine mount ( ie: NZ0000015). The engine came with only 1 shim pre installed and a second much thicker shim which I am assuming is the break in shim. Any idea why the different number of shims pre installed ?
I don´t know what size the pre installed shim is as it doesn't mention it anywhere in the enclosed paper work.
On a different note. Until recently we have only been allowed to legally race .21 motors in truggy class here. As of 2008 .28 motors will be legal for racing. What are some of the veiws on .28 vs .21 in truggies. A few guys have been racing the Go tech .28 6 port in non sanctioned events and it seems a really wicked motor for the heavier truggies. I actually purchased my 5 port to use in a truggy, but now the rules have changed I might use it in my buggy and think about a .28 6 port for the truggy ???
grizz1 is offline
Old 11-23-2007 | 01:12 PM
  #547
Since we race at the same tracks I can tell you that if you have an 086 and 053 pipe in your box with a short U header and a longer Torque header you will have a set up for any track in the midwest.
You will be most happy with the 053 at indoor LH this winter. You may even want to try the Dynamite 007 torque pipe but I think the 053 will give plenty of bottom end.
satoch is offline
Old 11-23-2007 | 01:28 PM
  #548
vr6's Avatar
vr6
satoch- thanks for the input. i will be racing at leisure hours and maybe an indoor track in iowa, so i hope that the 053 will work in iowa also, both track are tight high bite tracks
do you still have that 5 port motor, or do you have a new one. i'm thinking about getting a new motor, but wanted to HOPEFULLY try out a 5 port sometime when i see you at lh
vr6 is offline
Old 11-23-2007 | 01:33 PM
  #549
I still have the 5 port but have a 3 port coming next week also as a practice motor. I also have a turbo button for both coming.
satoch is offline
Old 11-23-2007 | 03:07 PM
  #550
Thanks Russ, LOL it's kinda weird keeping track of the differences in my oldie vs changes since then....The odd thing to me is I didn't think i had any difficulty breaking in the engine with the shims I have....
Well I'm on my 4th gal now (i know for over a year of having the engine, thats pretty pathetic) with the same conrod, same sleeve, same piston, same bearings and the updated carb that i bought a while back...I've got backup parts for when they do finally wear out....when ever that is
Old 11-23-2007 | 03:21 PM
  #551
the 053 will give you plenty of bottom, but the HN 2047 is also a good pipe for the 7port...ive got the 2047 on the way, so ill post how good it really is...
Old 11-23-2007 | 07:10 PM
  #552
rossoh10's Avatar
I tried the OS 2050 on my Go 5 port and must say this is the pipe I`m sticking with.......I am averaging easy 10 minute run times per tank...I was running a OS 2060.With the 2060 my run times where around 8-9 minutes.I very,very little top end and gained more bottom....The track I run on is very large and is a on throttle track.....Oh and my 5 port is not modded and was running rich.....I believe I could still lean it out some more(many clouds of smoke)
rossoh10 is offline
Old 11-23-2007 | 09:58 PM
  #553
I just got my .28 six port today for my Losi 8T. I'll have it out for testing on Sunday and let you know my initial thoughts on it.
revo_race is offline
Old 11-23-2007 | 09:59 PM
  #554
remember to use the extra shim for break in...
Old 11-24-2007 | 12:33 AM
  #555
Maximo's Avatar
how does the motor sound with the 2050 ???? 2050's can be awesome sounding pipes ...
Maximo is offline
