Like Tree3Likes
Tamiya TRF415
Old 07-15-2007 | 02:49 AM
  #18856
PizzaDude's Avatar
Originally Posted by rctouringracer
Hey guys,
Does anyone know the part numbers for the Tamiya SSG blue upper & lower chassis for the MRE.
Thanks in advance.
49429 TRF415MSXX Upper Deck (Blue)
49430 TRF415MSXX Lower Deck (Blue)
PizzaDude is offline
Old 07-15-2007 | 05:21 AM
  #18857
Xanavi_R34's Avatar
Originally Posted by Tek Nickal
If you can't find the MRE, the MSXX may be a better option depending on what you want, it comes with a center one-way as well as a front one-way. Also a thinner chassis that is 2mm, where as on the MRE its 2.5mm. The MSXX does not come with the titanium screws though. Other than that they are both great cars to run.
is this true??? then what comes standard screw with the MSXX???
Xanavi_R34 is offline
Old 07-15-2007 | 08:24 AM
  #18858
Vicko's Avatar
i belive black steel screws comes with the msx and msxx kits
Vicko is offline
Old 07-15-2007 | 10:16 AM
  #18859
PizzaDude's Avatar
Originally Posted by Vicko
i believe black steel screws comes with the msx and msxx kits
You're correct!
Old 07-15-2007 | 03:57 PM
  #18860
Burlap's Avatar
Originally Posted by SpeedDesignz
Any idea when.................
Tamiya is going to realease a predecessor to the 415?
yea granted the 415 is a proven chassis .... but could there be a change to the "Cookie cutter" chassis ?
I know Losi is thinking ..... outside "the box"
(my type R is killing my MRe on carpet)
could we expect Tamiya to try somthing radical ??? I know Xray would follow on the footsteps ... if you know what i mean :P....lol
Release a predecessor to the 415? Do you mean a successor? Cos there are plenty of 414s about second hand.
Burlap is offline
Old 07-15-2007 | 07:21 PM
  #18861
Xanavi_R34's Avatar
thanks but isn't the black steel screws titanium too??? it is just painted in black...
Old 07-15-2007 | 07:40 PM
  #18862
Tek Nickal's Avatar
The black screws are steel. They aren't titanium screws painted black. You can always get titanium screw sets for the MSXX if you aren't satisfied with the steel screws.
Tek Nickal is offline
Old 07-15-2007 | 08:36 PM
  #18863
rctouringracer's Avatar
Hey guys,
Ran my TA05R today at my club race and a just clipped a wall and bent one of my DJ pro module rear arms, out one degree.
Does anyone have a bent module they'd like to sell?
PM me if so.....
rctouringracer is offline
Old 07-15-2007 | 10:08 PM
  #18864
Xanavi_R34's Avatar
oh okay... so meaning to say I'm going to spend another dime on the titanium screws... sigh...
Old 07-15-2007 | 10:44 PM
  #18865
Tek Nickal's Avatar
No one said that titanium screws were necessary to run the car. Steel screws are cheaper to replace if you strip them, and that happens a lot unless you use good tools (hudy). The performance gain that you get from using titanium screws isn't going to change the car much...at all.
Old 07-15-2007 | 11:55 PM
  #18866
Xanavi_R34's Avatar
oh is that so..? but people who uses 415 and uses titanium screws in it is much lighter and much better to use...
Old 07-16-2007 | 12:54 PM
  #18867
Grizzbob's Avatar
Super Moderator
Honestly I wouldn't waste my money on them, in screws, titanium is not that much lighter than steel(its weight is between steel & aluminum), & the strength gain isn't enough to really warrant spending that much cash on them, imo. I've stuck with steel & I see no need to go any other way, strong, reliable, & most importantly, affordable.....
Grizzbob is offline
Old 07-16-2007 | 02:05 PM
  #18868
JayL's Avatar
No point in a complete ti kit anyway, you want to stick with steel on the screws that go through the bottom of the chassis. This way you will not raise the Center of Gravity. Use ti on the 'top' of car.
JayL is offline
Old 07-16-2007 | 07:40 PM
  #18869
Xanavi_R34's Avatar
okay sir... thanks for the info... will save my cash for some other RC spending instead...
Old 07-16-2007 | 08:22 PM
  #18870
maxepower's Avatar
Talking STEEL vs. titanium!
I would like to add to this conversation by saying if your going to use steel screws, use the stainless steel screws. The kit screws, I believe are a little softer than stainless and the weight is about the same. There are many aftermarket companies that make them.
I also would add if your going to do races that there are weight limits then stick with stainless steel but if you run where there is no minimum weight requirements then getting the car as light as you can is like free horsepower.
I would take advantage of any performance gains, since the screws have to be in the chassis anyway, why not spend a few more dollars to make the car lighter and quicker coming in and out of the corners? The average racer probably can't feel the difference but you'll have the potential of saving a few tenths on the lap times for sure!
Just my 2$
maxepower is offline
