Like Tree1Likes
Sirio engines thread
Old 04-17-2007 | 01:15 PM
  #1981
nikoskar's Avatar
Originally Posted by Sirio2127
Hi Niko, The sirio 21 cl7 r is not relised to the public yet only factory drivers have them so far. Regards Jeremy.
I can buy it from our local distributor.I just want to know if this motor it has better perfomance than the Picco Evo 2.
Thanks in advance
nikoskar is offline
Old 04-18-2007 | 12:37 AM
  #1982
M7H's Avatar
M7H
Well as it is not released to the public yet, nobody really knows.....
M7H is offline
Old 04-18-2007 | 10:58 AM
  #1983
Racing4Evo's Avatar
Thanks in advance
Yes, that motor is extremely fast! I think it's faster than the Plus 35 but probably lacking in the torque compared to the Novarossi. That's always been the case with Sirio so you just gear accordingly.
Racing4Evo is offline
Old 04-18-2007 | 01:58 PM
  #1984
nikoskar's Avatar
Thanks a lot Racing4Evo.
Regards,
Nick
nikoskar is offline
Old 04-20-2007 | 04:41 AM
  #1985
kyoshosan's Avatar
Hi guys,
What´s the diference between the Sirio EVO 3 .12 Turbo 3PT STI IFMAR and the Sirio EVO 3 .12 Turbo 3PT STI EFRA ? Seems to be on the crackshaft, but on the Sirio Website both engines have the same specs! Asking that because on The Border there is a almost $100 diference in their price. Is one more powerfull than the other in any way ? Thanks in advance.
http://www.the-border.com/product.ph...&cat=85&page=1
kyoshosan is offline
Old 04-20-2007 | 04:58 AM
  #1986
Dynamite's Avatar
you are correct, it is the crankshaft.
IFMAR version has larger crank hole diameter and more power.
Dynamite is offline
Old 04-20-2007 | 05:04 AM
  #1987
M7H's Avatar
M7H
Originally Posted by kyoshosan
Hi guys,
The price difference is because with the IFMAR engine, You get an inline pipe too, the EFRA engine is only the engine.....
M7H is offline
Old 04-20-2007 | 07:55 AM
  #1988
kyoshosan's Avatar
Lightbulb
M7H,
You are right! I didn´t notice the inline pipe. BUt do you know if there is a performance diference between them ? Thanks.
Old 04-20-2007 | 09:27 AM
  #1989
M7H's Avatar
M7H
The IFMAR version will have a less limited crank, so this engine should perform better, but if it is noticable, I don't know..
M7H is offline
Old 04-20-2007 | 08:29 PM
  #1990
twiggy's Avatar
if your rules allow it then go for the ifmar.
as they say, bigger is always better
twiggy is offline
Old 04-27-2007 | 02:04 PM
  #1991
Default t5 sti
would you consider sirio t5 sti better than the sirio t3e sti.i cannot understand why the t5 sti is cheaper here in Greece from the t3e!! as far as i can see from other online shops ,both engines have the same price and the same specs,except from the ports on the sleeve.which one would you guys buy?
nickiphorosn is offline
Old 04-28-2007 | 07:55 PM
  #1992
Registered User
Hello I'm looking for some information. I'm far from new to RC but I just got my first AAC construction engine. Its the Sirio S21-WRC. I'm just wondering if these engines need any kind of special care compaired to the ABC engines which is all I've been running up untill now.
Dyscrasia is offline
Old 04-28-2007 | 08:46 PM
  #1993
twiggy's Avatar
i run the same engine. just make sure to warm it up before you go out onto the track. i usually start up the engine about a minute before the previous race has finished.
also keep a check on the conrod and bearings.
twiggy is offline
Old 04-28-2007 | 08:48 PM
  #1994
Sirio2127's Avatar
Hello, The ancer to your question is yes and no. The main thing with an aac construction engine is when you first start the engine don't rev it cold. what i do is rase the idle with the transmitter triger just a litle and hold it there with my outher hand on the engine head and wait antill the engine begens to get some temp into it. AAC engines will ware much faster when run cold you must pre warm them befor you start kaining them. That will make your engine last longer. the outher main thing with a sirio 21 wcr intregral aac engine is the liner it has 4 screws holding it to the block they are not m3 or m4 screws there imperal size you must use a 2/32 of an inch hex key this is unique to the 21 wcr engine all the outher screws are metric sizes. apart from that run it as per any normal onroad engine use a high quality fuel somthing like tornado or werks white lightnig. 10% oil max for this engine and efra 2013pipe and conical header for max paformance the efra2008 is good the the 2013 is better. Let me know if you have any more questions. Regards Jeremy.
Sirio2127 is offline
Old 04-29-2007 | 02:07 AM
  #1995
any answer to my question???
