Like Tree1Likes
Sirio engines thread
Old 03-23-2007 | 04:41 AM
  #1966
Originally Posted by tenderfoot57
Hey guys I have a quick tuning question for ya. I am running a sirio sti .12. The thing has crazy fast top end but I am getting beat out of the bottom. I am running the sirio pipe and the sirio #7 plug, 30% nitro, rrr with 15t and 61t 1st gear. I have tightened my cluth about as far as I dare without sacrificing performance and I am still getting beat out of the hole. The engine runs all day at 246-248 degrees F. I noticed if the engine idles for more than 10 seconds that it would not respond when I gave it full throttle. What I mean by this is that when I pull the trigger the engine continues to idle for another 3-5 seconds before it responds once it responds and clears out it continues to run just fine, it is just a step slow coming out of the corner. I don't know if it is lean or rich on the bottom or do I need to go back to the Nova to get the bottom end that I need. Thanks for the input.
TF
Hey u might be a little to rich on the bottom. You can lean the bottom and richen the top as much as u have leaned the bottom and u should be good
bullie1 is offline
Old 03-23-2007 | 01:40 PM
  #1967
Sirio2127's Avatar
Originally Posted by RC=Realy_Costly
would u advise running this with an evo3 sti?
is there a difference in preformance?
You will get the same paformance its simply the conector. I use to mod them by putting around joiner 9 springs because if you get a hit in the right spot it can leak. but paformance no difrence. Regards Jeremy.
Sirio2127 is offline
Old 03-23-2007 | 03:08 PM
  #1968
RC=Realy_Costly's Avatar
thanks for all your advice mate.
cheers remo.
RC=Realy_Costly is offline
Old 03-28-2007 | 05:30 AM
  #1969
EVIL-ET's Avatar
is the skyline vr12-plus pipe any good with the sirio .12 evo 3 sti
thanx
EVIL-ET is offline
Old 03-28-2007 | 10:06 AM
  #1970
try runing a # 5 or 6 plug small blks do better with a hotter plug
michael 1 is offline
Old 03-28-2007 | 02:25 PM
  #1971
Racing4Evo's Avatar
thanx
It works great and in some ways better than the Sirio 2611 pipe. You gain a lot more fuel mileage but you lose a little bit of that top end power.
A lot of racers prefer it over the Sirio 2611.
Racing4Evo is offline
Old 04-01-2007 | 09:30 PM
  #1972
Default troubles
I have an issue with my sti..
I cant keep the motor in tune.. I think the plug was going out.. when I changed it... the motor ran hot. not over 250. but the motor really is acting up. I took the motor out..
Anyone have tips for tuning.
I cant keep the thing running at a decent idle... I have to run it fast to keep it alive.
I am going to break in my new motor.. I just dont want the same issuses
If I need to replace anything. what do you think it would be.? It seems to have good compression... its still fast but the motor seems to be slow if the temp is not at aleast 220.
wiggindude is offline
Old 04-01-2007 | 10:35 PM
  #1973
nikoskar's Avatar
Guys what type of motor you prefer.
Sirio STI-T3 or
Sirio STI-T5 ?
nikoskar is offline
Old 04-02-2007 | 02:06 AM
  #1974
twiggy's Avatar
if the engine starts revving high at idle then back off idle until it starts to drop revs. if idle gets too low then richen up botom end too. and bring idle back up.
twiggy is offline
Old 04-02-2007 | 02:09 AM
  #1975
twiggy's Avatar
Sirio STI-T3 or
Sirio STI-T5 ?
i don't really think the t5 is that much faster than the t3. if anything, what you gain in speed you will lose in fuel mileage. i don't think the 5port is allowed to run at sanctioned events.
twiggy is offline
Old 04-02-2007 | 02:36 AM
  #1976
nikoskar's Avatar
Thanks a lot Twiggy.In our country the 5Port is allowed at local races.I see the T3 running at the track and was really fast.But the 5port was just arrived from our local distributor.What exhaust do you prefer for tight tracks?Is there Conical pipe for .12 as there is for .21 Sirio engines?
nikoskar is offline
Old 04-02-2007 | 03:44 AM
  #1977
twiggy's Avatar
i always run thre sirio 2611 exhaust pipe.
evn on tight tracks and open tracks. i usually play with gearing.
twiggy is offline
Old 04-16-2007 | 10:37 AM
  #1978
nikoskar's Avatar
Do we have some owner of S21 CL7 R STI?
nikoskar is offline
Old 04-16-2007 | 06:40 PM
  #1979
Sirio2127's Avatar
Hi Niko, The sirio 21 cl7 r is not relised to the public yet only factory drivers have them so far. Regards Jeremy.
Old 04-16-2007 | 06:52 PM
  #1980
kyosho 444's Avatar
what is the best engine sirio has?
kyosho 444 is offline
