Sirio engines thread
#481
Originally posted by afm
Talking about reliabilty............. Adrien Bertin just won the 2004 European Championship (EFRA) for 1/8 th scale with his Kyosho/Sirio........so one big tournament won, one big tournament lost doesn't prove anything TG......
Peace on you!!
AFM
Peace on you!!
AFM
#483
Originally posted by TKT
About Josh's engine, he didn't have any tuning problem at all. he got mechanical fail on engine and it was keep blowing plugs ( at list 4 or 5), which give enough clue to say that conrod is gone or piston cracked, btw, are you sure he wasn't running LCI? I saw what he was running, on his pit table, did you see it?
Please notice, that my coments here to not drive down the brand, I hate when reps are blaming racers for engine failuers-run in was done wrong, too lean, too reach etc, etc etc.
#484
Originally posted by Top Gun 777
.................................................. ..............About Josh's engine, he didn't have any tuning problem at all. he got mechanical fail on engine and it was keep blowing plugs ( at list 4 or 5), which give enough clue to say that conrod is gone or piston cracked, btw, are you sure he wasn't running LCI? I saw what he was running, on his pit table, did you see it?
BTW you can also constantly blow plugs with bad fuel and/or wrong co´mpression ratio,not necesarily conrod or piston failure. At any rate the only one that can answer that question is Josh himself. Lets not jump on to conclusion so easily.
AFM
#485
Rep always blame racer in engine failure.
#487
Yes, my native language isn't english, I came from Russia and I learned English here. Even that I can separate by looking on the posts who sad what!!!!!!!!!!!!!!
BTW, if you know Josh, ask him about me, you might find something very interesting.
Best regards
Edward
#489
Hey guys, lets cool it down and put things in it's real proportions. This whole issue started by somebody posting a picture of his broken crank, and questioning the quality of Sirio engines.
After observing them I posted my opinion that it was caused by long periods of overheating, which was then admitted by the owner.
TG you jumped in, selling the idea that Sirio engines have bad quality and that Nova based engines were superior blah, blah..... and somebody else, posting pictures, said that not only Sirios break but also Nova based engines do, if mistreated and or badly tuned, idea which i support and also that there is no perfect engine.
You are a manufacturer and I bet your engines have their share of problems to, but it is not ethical for you to induce a thinking that every engine out there...except your's..... is a piece of $%&&.
Give constructive advice, because you are not going to sell more engines by trashing the competition.
State your strenghts and prove them on the track with results, and help others, if you wish, giving advice on how to avoid desaster, but not throwing $%$& with a fan over other brands.
AMEN
AFM
AMEN
AFM
#490
If engine turns, it doesn't mean that conrod is OK, it might not be broken on pieces, butif it loose on pin ( ery common problem) it will be creating a lot of debry,which is going to combustion chamber, light up ( there is enough temp to light up AL) and burn out filament of glow plug. It also can be AL sleeve got loose in case and creating Al debry, goes to combustion chamber etc. It is still mechanical failure.
Whatever reason was, but there were more broken Sirios then Novas-this is bottom line. So, I still saying that Sirio is much less reliable then Novas based engines. In the mean time they have some very good design ideas there.
best regards
Edward
You didn't insult me at all, don't worry about it.
#491
AMEN
AFM
AMEN
AFM
You can do as long as you want to, but it is not ethical to balme racers in everything.
#493
Actualy I wasn't against Sirio and I sad, that reps always blaming racer for engine failure and you are the Sirio rep and you are doing it.
Yes I agree with you on not being ethical to allways blame users for all problems, but statistically it is most of the time by abuse or misuse that problems ocurr, and that is when serious tech support comes on the game, and makes the difference in brands.
AFM
#494
It isn't true that reps "allways" blame users and/or racers for engine failures........ here you go again asuming false conclusions. Sirio and other brands, and I've quoted several examples (JP, STS, Nova Sirio, etc, posted in this forum pages), have replaced any damaged engine or part......... when failure is clearly by bad production failure, but not when you can clearly see it is by misuse or abuse........and I bet you have same policy...or are you going to tell me now that you give unlimited guarantee over racing engines????? Show me a brand that guarantees racing engines of any kind.
AFM
AFM
This is my policy.
#495
...had just as much HP as anyone else on the track.
1Likes
