Ninja Engine by GRP
#691
it's too rich. get that puppy up around 250F.
lean both needles 1/8 of a turn to start. when you lean the low end you will have to lower the idle a touch as well.
when you get the top end right you'll probably need to tighten the two speed screws about 1/4 turn each. it will make so much more power it will shift too early.
#692
Originally Posted by randay
Seems like the carb on the mr12 likes to come loose? I lost the carb screw today. I think its because the insulator is tapered so it kinda gets squeezed up and out. I replaced the screw and tightened it down good, didnt move after that. Another guy on the track running the ninja also had his carb move upwards out of its socket.
Anyone else had anything like this happen?
maybe u didnt tighten it the first time as it come loose in the box to suit to different cars carb mounting positions =-)
#693
#696
Originally Posted by 3,2,1,..GO!
Hello people,,can anyone tell me who has the Ninja 21 size and pipe in stock?????? I cant find anyone who has it.
They know a good thing when they see it!! I had a hard time finding some, but when I did- I got three
Try Brooklyn Hobbies- I think he has some in now.
#697
Originally Posted by sandrixx
Hi all!,, what other turbo plugs can i use if the ninja c6 or c7 arent available?.. this is for my Ninja MRB01 engine.., thankx all!!!
#705
Originally Posted by nitrodude
I use NR plugs on mine and it runs fine, no signs of leaking.
