Ninja Engine by GRP
Old 04-02-2007 | 12:59 PM
  #691
cdelong's Avatar
it's too rich. get that puppy up around 250F.
lean both needles 1/8 of a turn to start. when you lean the low end you will have to lower the idle a touch as well.
when you get the top end right you'll probably need to tighten the two speed screws about 1/4 turn each. it will make so much more power it will shift too early.
cdelong is offline
Old 04-07-2007 | 09:16 AM
  #692
Originally Posted by randay
Seems like the carb on the mr12 likes to come loose? I lost the carb screw today. I think its because the insulator is tapered so it kinda gets squeezed up and out. I replaced the screw and tightened it down good, didnt move after that. Another guy on the track running the ninja also had his carb move upwards out of its socket.
Anyone else had anything like this happen?
maybe u didnt tighten it the first time as it come loose in the box to suit to different cars carb mounting positions =-)
lance04 is offline
Old 04-09-2007 | 09:21 AM
  #693
spenzalii's Avatar
You weren't lying about that. I adjusted the clutch nut a bit to let it rev higher in the power band and that made so much of a difference it's not funny. It screams. And yes, the tranny shifted way too early. Gotta get new springs for the 2 speed to keep that thing in check.
spenzalii is offline
Old 04-09-2007 | 07:25 PM
  #694
3,2,1,..GO!'s Avatar
Hello people,,can anyone tell me who has the Ninja 21 size and pipe in stock?????? I cant find anyone who has it.
3,2,1,..GO! is offline
Old 04-10-2007 | 03:23 AM
  #695
sandrixx's Avatar
Hi all!,, what other turbo plugs can i use if the ninja c6 or c7 arent available?.. this is for my Ninja MRB01 engine.., thankx all!!!
sandrixx is offline
Old 04-10-2007 | 07:12 AM
  #696
cdelong's Avatar
The Ninja's are getting scarce because everyone is scooping them up They know a good thing when they see it!! I had a hard time finding some, but when I did- I got three
Try Brooklyn Hobbies- I think he has some in now.
cdelong is offline
Old 04-10-2007 | 08:55 AM
  #697
choisan's Avatar
o'donnel and nova rossi are sure OK, i am using.
choisan is online now
Old 04-10-2007 | 09:10 AM
  #698
Suspended
Tim Findle has a ninja engine if you know what I mean, hunny
RCgirl69 is offline
Old 04-10-2007 | 02:39 PM
  #699
am
If you have trouble getting the Ninja enignes, try the Falcon Line. Same engines, basically.
am is offline
Old 04-10-2007 | 08:59 PM
  #700
sandrixx's Avatar
okioki!,, thankx for the reply bro!!,,., il use odonnel 97's for sure..oxxx!!
sandrixx is offline
Old 04-11-2007 | 02:39 AM
  #701
choisan's Avatar
I am using 99 on 1/8 in hot weather city and 97 for 1/10 on-road touring.
Old 04-11-2007 | 07:17 AM
  #702
cdelong's Avatar
you should stick with the Ninja plugs. I believe they have a different taper than the other brands mentioned.
cdelong is offline
Old 04-11-2007 | 04:41 PM
  #703
HarKonnenD's Avatar
Also, Mike Swauger stated using any other brand of plug will void the warrenty on the Ninja.
HarKonnenD is offline
Old 04-11-2007 | 05:32 PM
  #704
I use NR plugs on mine and it runs fine, no signs of leaking.
nitrodude is offline
Old 04-11-2007 | 06:43 PM
  #705
choisan's Avatar
me too, no signs of leaking and same running time. I do not know how the taper makes the difference, but as long as it provides the same running time, i am ok with it, and my machine is on the second set of bearings and conrod, no damage so far.
