Ninja Engine by GRP
Old 06-03-2007 | 07:29 AM
  #841
RR's Avatar
RR
Originally Posted by Corse-R
Have you checked the combustion chamber height? how high came it? still come too low or ir a thing that has been fixed on the new units? My last R01A came slightly higher than the original R01's.
I have still some very nice STi's but.. planning to get a T01 on the next weeks.
have not check that yet...
but after the run in today, interior of the MRT still look like new
RR is offline
Old 06-03-2007 | 01:45 PM
  #842
bread is offline
Old 06-03-2007 | 05:00 PM
  #843
Grinder's Avatar
Originally Posted by %Yanlei%
Hi all,
Something really wierd happened today. Picked up a new Ninja .21, Murnan modified full ceramic, pre-run in...Ran great, did 1.5 litres through it on the first day out without leaning the top or bottom end too far out. The engine ran fine all day. Took it home to check out the internals for the first time to make sure everything was ok and I found something wierd had happened.
There were two 5mm long triangular shards of metal in the crankcase...but no other evidence internal damage whatsoever. It seems that the pieces had not been bouncing around either as the inside of the case and other internals looked fine. The pieces turned out to be from the bottom of the exhaust port side of the piston. That has not happened before with my other .21 Ninjas. I guess that I will have to replace the damn thing as the balance will be all out etc. etc.
Anyone had a similar problem with a Ninja? Plain wierd considering the engine was not run hard in the slightest and still on the rich side...
I wonder if you removed the backplate with the piston at BDC. If the piston is not all the way up, it will break when the backplate is removed.
Grinder is offline
Old 06-03-2007 | 05:54 PM
  #844
%Yanlei%'s Avatar
Corse and Uriah thanks for the info.
The piston was not at BDC when the backplate was removed to the best of my knowledge, HOWEVER as the sleeve and the engine interior is in perfect condition and the broken pieces had not been smashed into many small pieces I believe that the piston must have come back down while I was removing the backplate and as Uriah said, broke the side of the piston. Cannot be anything else I guess!
If anyone is considering the Murnan tuned R01 it is very reliable with a great powerband, I would definitely recommend it
%Yanlei% is offline
Old 06-04-2007 | 03:55 PM
  #845
wallyedmonds's Avatar
its a good thing i read this tread
thx mike
wallyedmonds is offline
Old 06-04-2007 | 04:21 PM
  #846
Originally Posted by stefan
No Mike, the MR.12 kit with the pipe is € 320 (420 USD).
When I look around at US shops, the difference between NR and Ninja .12's is also 20-30 bucks, not that much, right?
Btw, I just found the Plus 12-3 for €269, which is actually cheaper than the MR12.
NR Plus 12-3
When I lived in the States it was the distributors that messed up the prices for engines, especially Trinity when they had the monopoly.
I know that the European importer have been putting pressure on NR and it seems to have an effect.
nr motors in toronto are nutty $ to get now just nuts so im thinking ninja now.
Old 06-04-2007 | 04:27 PM
  #847
Hmm, what's next? Only Mugen fuel? or maybe genuine Ninja mechanic gloves and a special screwdriver for carb adjustments?
Grade A American bullshit if you axe me..
the taper is different just like os,and sirio
you have to use there plugs if you want the button to stay good longer.
Old 06-04-2007 | 05:12 PM
  #848
JetMD's Avatar
I think his point is why the different taper? Why not standardize them? Why can't all turbo's be the same? Oh wait, that would make too much sense and they wouldn't be able to charge $10 a plug!
JetMD is offline
Old 06-04-2007 | 07:31 PM
  #849
10 bucks where can i get a plug for 10 bucks
ya all motor comps have there theory on that to make there motor run better faster stronger
we can rebuild it
and its not just the taper its the length of it too.
Old 06-05-2007 | 12:22 AM
  #850
M7H's Avatar
M7H
And you didn't notice that?
M7H is offline
Old 06-05-2007 | 12:25 AM
  #851
M7H's Avatar
M7H
Every engine I have ever run in (and this is a lot!) still looked new after break-in.....
M7H is offline
Old 06-05-2007 | 08:16 AM
  #852
we can rebuild it
If you buy the 5 pack the cost is under $10 a plug.
THE DOCTOR is offline
Old 06-06-2007 | 11:15 AM
  #853
KMR's Avatar
KMR
Hello I’m new to Nitro and I’m ordering plugs for my new MR12 T01A and I wanted to double check on a couple things.
What % nitro should I run? Everyone locally has told me 30% ??
Also should I run a #6 or #7 Ninja plug if I want to run 30% nitro?
KMR is offline
Old 06-06-2007 | 11:16 AM
  #854
KMR's Avatar
KMR
Sorry I don’t know if it matters but I’m running on-road with a new Xray NT1.
KMR is offline
Old 06-06-2007 | 02:24 PM
  #855
Corse-R's Avatar
If your rules allow you to use 30% nitro, go ahead with 30%. Just make it sure that combustion chamber height is enough high when running 30% for not grenading it.
Get a pair of #6 and a pair of #7 and try for yourself, here people running them is biased between those two. Cannot give you a sure answer, but, the ones I tried (and liked it...) went with a #7 plug.
Corse-R is offline
