Ninja Engine by GRP
#676
For future reference, all of Team Mugen's notes on the .12 that have been posted here since the engine's release, are now in the .12 Engine KB in the Engine FAQ section. This includes break-in, engine temp and recommended plug for nitro %.
#677
Quick nitro noob question. I run the #6 Ninja plug in my .21 buggy on 30% O'Donnell. It works great with no problems. But I hear about guys running a hotter or cooler plug for certain fuels and conditions. What plugs are hotter (higher number or lower number) and when would you change? What makes them different? Is it more or fewer coils? Like I said. The #6 is what I was told to run and it's been good. I just want to have a good understanding.
#679
The higher numbers are colder.
#682
Most of the colder plugs are made with a larger size of wire. Not that you can see a big differance but I notice that the colder plugs usually last a lot longer then the hotter plugs.
#685
Hot Tip.....
When using an Exergen DX501 with the Ninja you need to place an exhaust gasket over the Exergen head or else the gun's window WILL contact the plug electrode and cause damage. Push the gasket up as far as it will go- this will stop the sensor window from hitting the electrode. I think the DX501 is the only Exergen model that has this problem with the Ninja's head.
Exergen has been made aware of the situation and will be informing the engineers of the problem.
My sensor window has plug material on it from the contact. They were kind enough to offer me a repair/replacement/calibration for informing them of the Ninja's head design.
#686
Originally Posted by randay
This is probably just semantics but the spring is what decides how much force you need for the shoe to touch the bell. same spring tension, same amount of force, lighter shoes, more velocity(rpm) required, and heavier shoes, less rpm. but the force is always the same. its up to your motor to keep increasing that force for a hard "hit" or for your motor to wuss out and stutter for a soft "hit" or even just slipping.
i could be wrong but thats how i see it.
My serpent clutch has kyosho weights, stock backplate and stock shoe, JP spring and normal gap settings.
But when you try it....nobody home...nobody home.... engine starts to make serious rpm.... and kaboem your car launches towards the horizon (or the closest fence :P)
It's what we call a "Italian" clutch, gives a massive punch!
it requires a well set up car, coz it's more like a switch....
depends on drivingstyle if you like it
#688
Hello guys, I am trying to find The cheapest And fastest shop to get a ninja r01 the first version crank shaft for a friend of mine. If some one could post some links it would be much apreated. Regards Jeremy.
#689
Seems like the carb on the mr12 likes to come loose? I lost the carb screw today. I think its because the insulator is tapered so it kinda gets squeezed up and out. I replaced the screw and tightened it down good, didnt move after that. Another guy on the track running the ninja also had his carb move upwards out of its socket.
Anyone else had anything like this happen?
#690
I'm trying to get a handle on tuning this MR12 I'm finishing up the break in on. When I nail the throttle, it's a slight bog, then the engine falls flat on it's face just about when it's set to shift into second. When I let off the throttle, the idle hangs up a bit then goes back to normal. I'm pretty sure the engine was not overheating (temp aroung 215 on a +-60 degree F afternoon). Are both needles set too rich right now?
Also, can anyone comment on the power band on these engines? Should I gear it short like the CRF (I'm guessing nowhere near as short as that engine, but still) or will it pull whatever you give it?
All I know is compared to my NSR12, this thing seems (and sounds) silly fast.
