Ninja Engine by GRP
Old 06-14-2008 | 07:31 PM
  #1426
Default Factory setup for Ninja .21 R01A
Hello, I was wondering if anyone knows the factory settings for the Ninja .21 R01A 7 port onroad engine?
chromie1 is offline
Old 06-14-2008 | 07:53 PM
  #1427
MugenDrew's Avatar
High Speed Needle; 4 and 1/2 turns out from fully closed (LIGHTLY seat it LIGHTLY)
Low Speed Needle; 1 1/2 turns out from flush with the face of the "thing you snap your linkage on to"...
MugenDrew is offline
Old 06-20-2008 | 09:15 PM
  #1428
jameslow's Avatar
Default Question: Ninja Mr12 T01A
Hi guys,
Im using the Ninja Mr12 T01A and i got a few questions to ask:
1. How many mm of shim should i put for 16%, 20% & 25%
2. What is the stock carb setting for the high end & low end
Many Thanks!
jameslow is offline
Old 06-25-2008 | 08:17 AM
  #1429
Other then the notorious tip breaking off, has anyone got anymore feed back on the Mugen FLS 2632? run time? other motors running them? top end? bottom end? low end? ect ect...
much appreciated
Baedarlboo is offline
Old 06-26-2008 | 02:03 PM
  #1430
sm1nts2escape's Avatar
Well it appears that the rumor about the bearings on the ninja being crap are true.My mr21r01a's front bearing started leaking on the 15th tank of fuel.Oh well I wanted to try out ceramics anyways but now I will not be able to run my car at 301 this weekend like I plannedI knew something was wrong when I was having a hard time getting the engine to tune last week and it's racing idle.Funy thing is a replacement ninja front bearing cost 17.99 but a tko ceramic bearing cost 14.99.
sm1nts2escape is offline
Old 06-26-2008 | 02:38 PM
  #1431
wingracer's Avatar
Go with the TKO. Best front bearings on the planet.
wingracer is offline
Old 06-27-2008 | 07:31 PM
  #1432
Just wanted to say that I went with boca bearings.I went with ceramics for the front and rear .I also orderd a new connecting rod, piston pin and piston clips while I was at it.Hopefully boca bearings doesn't take a long time to ship out there orders because I would like to be at 301 next weekend.
Front bearing = MR607C-2RS TH9/C3
Rear bearing = MR25414C TH9/C3
Old 06-30-2008 | 05:34 PM
  #1433
Well I got my motor torn apart today.The motor has about 20 tanks of fuel through it.The connecting rod had no slop around the piston pin and crank pin.I still think the craftmanship of the motor to be very nice.
Old 06-30-2008 | 10:56 PM
  #1434
kreamUNO's Avatar
I've ran 6 gallons on the engine, only thing i changed was the connecting rod and still has good compression/runs strong.
kreamUNO is offline
Old 07-15-2008 | 09:59 AM
  #1435
wmay11's Avatar
Default GRP tuned
Hi guys I am wannting to know if I can use OS plugs on my GRP tuned motor? And should I replace the rod after breakin, and what do these motors run like?
I have a JP Pro 99, JP RO3, 35 plus and modded C5, will that motor be better than these? Run a very tight track, run MRX4 and Evolvas.......clutch tips would be great.
All the best!!!!!!!!!!
wmay11 is offline
Old 07-23-2008 | 06:48 PM
  #1436
Hi Guys I am in need for Piston/Sleeve for the Mr12-T01A can anyone tell me where I can get parts to buy ?
reecek is offline
Old 07-24-2008 | 06:47 AM
  #1437
spenzalii's Avatar
http://www.acehardwarehobbies.com/in...p?cPath=29_153
spenzalii is offline
Old 08-18-2008 | 05:07 AM
  #1438
LogiK's Avatar
Hi all,
Anyone know the size of the MR12 TO1A front bearing ?
Thanks,
Cameron.
LogiK is offline
Old 08-19-2008 | 06:30 AM
  #1439
johnhsp's Avatar
Dear friend now i am using ninja MRT 21 onroad engine,can i know does ninja engine conrod same at GRPengine ,also plug,bearing all the same or not thank who helping me
johnhsp is offline
Old 08-19-2008 | 10:11 AM
  #1440
Seisick's Avatar
Originally Posted by LogiK
Hi all,
Thanks,
Cameron.
think
12x21x5mm
Seisick is offline
