OS 12 TzR
#1413
Just started up my TZ after 7 months of not racing temps stay under 200F when idol very impress
motor sounds great can't wait to race it.
#1414
hello... my TZ3 has just been through its 2nd race last weekend and i was satisfied with the performance running againts novas,TZ5,Sirio's S....
anyway after the race i decided its time to dissamble it for inspection on the parts..
1. the top of the piston has black spots, compression still very strong...
2. the internal bearing brown colour, no excessive play and no need to replace i think
3. the cshaft internal and sides were very brown/rusted i think
4. the conrod has quite a freeplay againts the cshaft pin, so new conrod coming...
btw i have replace the conrod...but there is still freeplay againts the cshaft pin
( so should there be no play or a little or what...) or the c/shaft pin has worn out also
BTW my engine has gone through 3- 4 litrs of fuel (25% nitro, P6 glow plug, and 0.4mm head clearance)
like to hear some comments on this conditions...thank u..
#1415
Take a look at post #1367 on November 19th last year. Not only was my big end to crank pin fit very bad, but also the top of the piston was badly pitted!
I returned the motor to Tower and they replaced it, no question.
I haven't run the motor yet, as I got a Nova Rossi in the interim period
#1416
Nosram it's good to hear Tower was so nice about that problem. Those were your pics back a while ago huh? That was a messed up engine.
#1417
hey guys
i think my front bearing is worn, the one under the carb.
after every race i notice alot of oily gunk stuck on the carb above the flywheel. the engine runs fast and stroing and the temps are consistent.
could it be the front bearing or maybe still a rich tune? what size is this bearing?
#1418
These are the prices from http://www.pro-s-futaba.co.jp/ they a crazy cheap at these prices i orded two of each
21535000 conrod 1980yen = $16 USD
21533000 piston and sleeve 4500yen = $38 USD
#1419
Originally Posted by mrgsr
hey guys
It only needs to be a little bit rich to force some oil out through the front bearing as it is lubricating it. Once this hits the flywheel it goes on the carb and anything else that is in the way of this radial arc.
Cheers,
Mike.
#1420
#1423
Originally Posted by Seisick
IS THERE IS SOMETHING ABOUT THE OS ENGINE THAT COULD BE IMPROVED,
BEARINGS, THAT'S IT THEY DON'T LAST LIKE NOVA'S, LUCKILY I HAVE ACCESS TO NTN OR SIMILAR BEARINGS WITHOUT ANY PROBLEM, FOR 1/3 THE COST OF ORIGINALS IN THE US
#1425
