Novarossi engines thread
#1009
I will be using an N12LL3 on My MTX-3 Prospec and was just wondering what pipe works best with these engines. Im not looking for an RPM pipe or plainly a torque pipe. Im looking for something in between.
p.s. How do these bad boys go??
#1010
Originally Posted by wendellc1
I have an LL3 engine. Going with 30% fuel, so I want to add .1mm shim to the head. When I took off the cooling head, the button is stuck with the sleeve. What is the best way to seperate them without any damanges. Thanks.
#1011
#1012
Wendellc1, I have had this happen before and it can be a major pain in the arse. Pull the sleeve out if you can (with head button attached and heat the sleeve with a heat gun. You may even want to lay an ice cube on the head button just before you try and pull them apart. The idea is to heat the brass up and keep the aluminum cool so the brass will expand away from the aluminum head button. Try not to pry on it as this can lead to damage. By all means DO NOT hydro lock the engine with fuel and force the button off, as that will almost surely bend or damage your connecting rod! Heat, Heat, Heat!
Rody, The best pipes I have tested so far for the .12 size racing mills have been the Mugen X12 one piece pipe and the RD Logics Turbo 2 one piece pipe. I think you will find they are both great. Myself, I would choose the Mugen pipe.
BK
BK
#1013
Originally Posted by asw7576
grinder : thank alot men !
racbj : so pinching tool works ? I want to know how long the sleeve will last after being pinched.
as promised....i'm updating regarding the above...
my 2nd race with the same engine,same exhaust, same fuel, another 3 per 5 minutes heats including 45 minute final....and it's still raouwkkksss...finish 5th...
didn't even stall once throughout the day...and was still using the old plug from last months race....
maybe i sounds a bit over... but its a fact...thanks
#1014
I compared them to my RDL Turbo II and they are really much better.
As a bonus, they have a chrome layer, which makes cleaning them abreeze. Mine looks just like the one on the pic after half a season.
#1015
Originally Posted by stefan
Guys, you definately must try the new Mielke pipes with the conical headers, they are awesome.
Ross
#1017
What do you guys think about the RS12T5S2? This is an older engine no? Trinity has it on their Ebay site for what looks to be a great price, so I'm thinking of ordering one. I'm assuming this will have more than enough power for any off-road racing, but the real question is buying an older engine like this a bad decision? (actually I'm not really sure if its a really old engine or not, but I have come to conclusion it probably is)
http://cgi.ebay.com/NOVA-ROSSI-12-TU...QQcmdZViewItem
#1019
Mugen Mr12 = Novarossi RS12S3 = RB x12
All parts of these engines are interchangable.
havent tried it yet as I'm still looking for a new conrod, the old one has seen better days.
195Likes
