Associated Reflex 14B/14T
#931
rms1776 kit purchased! are there any other recommended hop-ups you recommend while i have the patient open for surgery? what aftermarket suspension are you running? or could you do a mini breakdown of your components you have selected? thanks!
#932
#933
#934
Good evening all!
Can anyone with a 14B with the factory kit threaded shocks provide a couple measurements of both front and rear shocks?
Eye-to-eye length measurement uninstalled?
Outer diameter of the spring?
Hole size for the rod ends?
Thank you!
Thank you!
#935
#936
furitek 4600kv sensored system savox mini servo, gens ace 1150 battery and carbon towers from exotek i made my own motor plate which might go into production later and I have custom steering, rear shocks are in the front to tower then using a mini-b wing mount and wing that is all the upgrades.
#937
#941
Confusion by my side the LC (L6154) needs a 4mm shaft and 1,5x6 pin (L6233). The one I measured was the Steel bevel gear 16T inside the diff (L6199)
Regarding the AE center diff and the LC sleeper, I think it would be a pain as the bearing are not the same. But maybe Richard can give you more inputs on this point.
#942
The LC metal Differential pinion gear (L6154) looks pretty close to the plastic AE 21526 Pinion gear, though . Both have 15T. I don't have a LC available at the moment to check, but I have been able to test them and it was working.
#945
Been a while since I’ve played around with RCs. Decided to get a 14b yesterday at the LHS (they were getting rid of them at a great deal). The last time I raced RCs was with FM frequencies for the radio. While tuning this today with the steering and throttle, I am finding the steering to jitter every so often and occasionally the steering g goes all the way to the left for some reason (this is after I adjusted the steering trim). Any reason why this would happen.
Also, what are some necessary upgrades needed for this? I am reading how the gears could strip.
231Likes
