Associated Reflex 14B/14T >
Like Tree231Likes
Old 11-04-2025 | 07:43 AM
  #931
Originally Posted by usuallybill
rms1776 kit purchased! are there any other recommended hop-ups you recommend while i have the patient open for surgery? what aftermarket suspension are you running? or could you do a mini breakdown of your components you have selected? thanks!
furitek 4600kv sensored system savox mini servo, gens ace 1150 battery and carbon towers from exotek i made my own motor plate which might go into production later and I have custom steering, rear shocks are in the front to tower then using a mini-b wing mount and wing that is all the upgrades.
usuallybill likes this.
rms1776 is offline
Old 11-08-2025 | 07:02 PM
  #932
RossKo's Avatar
Originally Posted by Cain
be curious how the thickness is of the grease, but I don[t see why it woudn't be useful.
cases were received so just waiting on gaskets coming back.
Cain did you ever get gaskets to work in the diff housings?
RossKo is offline
Old 11-10-2025 | 06:02 AM
  #933
Cain's Avatar
Tech Legend
in the end got gaskets fro the LC Racing vehicles, those seemed to work out okay, you just need to factor in thickness if anyone else making these.
Cain is offline
Old 11-10-2025 | 05:45 PM
  #934
Good evening all!
Can anyone with a 14B with the factory kit threaded shocks provide a couple measurements of both front and rear shocks?
Eye-to-eye length measurement uninstalled?
Outer diameter of the spring?
Hole size for the rod ends?
Thank you!
jliddle is offline
Old 11-24-2025 | 11:39 PM
  #935
How ya liking it? It sure looks good raced by a few of them at Hobbytown
CincyRC is offline
Old 11-30-2025 | 06:03 PM
  #936
I can't find a furitek 4600kv and esc sold together as a combo. Did you have to buy yours separately? And there's a bunch of different savox mini servos so do you know the model number of the one you have? And the model numbers for your esc and motor?
underwater is offline
Old 12-04-2025 | 05:05 PM
  #937
Nevermind. Found a Furitek 5600kv Grom combo that looks like it should work. But don't know if it's a direct fit so I'll update when I find out. It will be awhile though because I'm still waiting for the buggy kit to arrive and now the esc and motor combo. I already have a receiver, now just need to figure out which servo to get.
Old 12-09-2025 | 03:02 AM
  #938
keuk's Avatar
Hi jliddle
Here is what I measured on the FT shocks:
E/E front: 67mm rear: 79mm
Spring outer diameter 16mm
Wire 1mm
Lower eyeball hole diameter 2,5mm
Ball diameter on top 4,3mm
keuk is offline
Old 12-12-2025 | 06:16 PM
  #939
RossKo's Avatar
any updates on the customer chassis? How does it get along
RossKo is offline
Old 12-15-2025 | 04:15 AM
  #940
strodedawg's Avatar
Do lc racing diffs fit with their pinions and ring gears? no drives shaft issues? what about the center diff can it be replaced with and lC one?
strodedawg is offline
Old 12-15-2025 | 10:21 AM
  #941
keuk's Avatar
Unfortunatly the inner diameter of the LC pinion gear that should go on the center diff outshaft has a smaller diameter than the AE. 3mm for LC, 4mm for the AE. The pin that locks the rotation is also shorter, LC 5 mm and AE 7mm.
You can use the LC rear and front diff if you also order the metal diff set from AE...
Confusion by my side the LC (L6154) needs a 4mm shaft and 1,5x6 pin (L6233). The one I measured was the Steel bevel gear 16T inside the diff (L6199)
Regarding the AE center diff and the LC sleeper, I think it would be a pain as the bearing are not the same. But maybe Richard can give you more inputs on this point.
keuk is offline
Old 12-15-2025 | 11:40 AM
  #942
keuk's Avatar
The LC metal Differential pinion gear (L6154) looks pretty close to the plastic AE 21526 Pinion gear, though . Both have 15T. I don't have a LC available at the moment to check, but I have been able to test them and it was working.
keuk is offline
Old 12-19-2025 | 07:10 PM
  #943
Default Battery Options
Hey. I got the reflex 14b with the reedy 1600 2s pack. What other betteries are you guys are running?
DrunkenChewy is offline
Old 12-19-2025 | 09:23 PM
  #944
keuk's Avatar
This one, and also the RUDDOG 2000 mAh by my side.
keuk is offline
Old 12-21-2025 | 10:31 AM
  #945
Default New 14b
Been a while since I’ve played around with RCs. Decided to get a 14b yesterday at the LHS (they were getting rid of them at a great deal). The last time I raced RCs was with FM frequencies for the radio. While tuning this today with the steering and throttle, I am finding the steering to jitter every so often and occasionally the steering g goes all the way to the left for some reason (this is after I adjusted the steering trim). Any reason why this would happen.
Also, what are some necessary upgrades needed for this? I am reading how the gears could strip.
Aqualung1102 is offline
