Motor Testing and Comparisons
#437
#438
The spring tabs, on the MHRacing equipment, work just fine. You're not using a lot of amps. The most I've used, on a regular basis, is about 12 to 13 amps. Alligator clips have less contact area than the spring tabs.
#439
Well, I figured out what was happening with the motor during my video. One of the slave tabs was not contacting quite correctly and therefore there was less load. Really spooky how it only happened at the one timing mark, but yeah. I was up past my bed time and tired, had to look at it again today.
EDIT:
After a second run through I determined timing at 46* for my motor.
EDIT:
Also, the F1 cars at the US indoor champs were extremely fast with the new lower resistance 25.5t motors....
#440
I also saw that the 48* time to target rpm was the lowest at 784ms. Hopefully the tabs did not cause it...I'll be handling the load master 2 with care not to rattle things too much...
Just as an fyi, that was the first time I have ever had an issue like that, but I normally check the connections everytime I run a test. On video that is a bit harder to do since I have my camera in my way. I really need to find a better way to record videos, just that thing they call time that I don't have a lot of...
EDIT:
Here is a run I did with the R1 v21s 25.5. Both the TP and the R1 used the same slave, Slot Machine II 25.5. These motors could not be more different, lol. The TP motor is way less efficient, but has a lot more rpm under load than the R1, but the R1 maintains a higher percentage of its rpm under load. The TP also draws a lot more current than the R1. The R1 I would time at 42.5* from my test. And the gearing ratios between the motors would be a huge swing...
#441
EDIT:
#442
#444
Yes, the time to target was affected as well. I have attached the test done after I discovered the issue. Notice I said I would time at 46*. 48* would be the max, but really the difference between 46 and 48 was negliable and would just lead to extra heat.
EDIT:
EDIT:
#445
based on your recent testings, which motor (17.5t) is "the best" ? Locally the HW G4R is still one of the most used by people, are there any other valid alternatives compared to this motor ?
Thanks !
#446
Or you could just gear them differently.
#447
I don't think there is a scenario where I would run the R1 over the TP motor.
With that said, if the HW G4R is the popular motor at your track, it seems like a logical choice to run. And on the other hand, lot of hype on the TP motor right now...
#448
To be quite honest, there really isn't one "Best Motor." It all depends on what you drive, the surface, the size of the track, how many corners there are, and your driving style. Check out my videos and you will see the differences of the motors.
#449
I say just buy all the best ones and use them accordingly based on a set time to the same target(13krpm), while noting how high the top rpm reaches...Pick the best motor matching your track's layout and stay ahead of the field: it feels like I'm cheating already...lol...
#450
FYI...
I just posted my video of the Team Powers V5S on The Jerry. I also decided to change the way I run motors on The Jerry. Remember, you can always go to WMHRacing.com to see the spreadsheets.
533Likes
